Pics of cut valve cover? - ok to cut while on the car?
Old Jan 6, 2002 | 08:09 AM
oryanh's Avatar
Default Pics of cut valve cover? - ok to cut while on the car?
I'm planning to install the toda Cam Gears and was wondering. Is it safe to cut the valve cover while still bolted on? If a small amount of aluminum shavings fall inside the timing belt cover... will that be a problem? I was hoping to use a Dremel tool and insure that rotation of the cutting blade throws the shavings away from the valve cover. Anyone have pics?
Old Jan 6, 2002 | 08:12 AM
Jason's Avatar
Default Re: Pics of cut valve cover? - ok to cut while on the car? (oryanh)
I would just take it off, it's easier and you'd be surprised how many shavings there will be...better safe than sorry...it only takes 10 mins to take it off, if that
Old Jan 6, 2002 | 08:16 AM
Back in Black's Avatar
Rather OG
Absolutely not. Take that thing off...
Old Jan 6, 2002 | 08:18 AM
oryanh's Avatar
Default Re: Pics of cut valve cover? - ok to cut while on the car? (typer98)
I'm not quite brave enough to install the cam gears myself... so the cover will need to be removed anyhow. I can however cut the cover myself, I'm more comfortable doing that, neatly. I've already purchased some Honda-bond and an extra valve cover gasket and plug seals. -I just wonder if it's necessary.
A "how-to" for cam gears sure would be nice...
hint-hint
Old Jan 6, 2002 | 08:20 AM
AssPenny's Avatar
Take it off.... you'll hate your self if you don't. Not only would it be a pain in the *** to be at that angle for so long, but metal is going to go every where...
Old Jan 6, 2002 | 08:21 AM
Jason's Avatar
cam gears are actually quite easy...just nice to have another set of hands in order to lock the gears together w/ a wrench so you can untorque the cam gear bolts...
other than that, just make sure the up marks are at TDC and you're set...it should take you 2hours if you're slow and careful...
Old Jan 6, 2002 | 08:26 AM
oryanh's Avatar
"lock the gears together" ?
Is it possible that it would slip and I would be screwed?
What I'm saying is, should I be within reasonable towing distance while I'm working on the car? -or is it fool-proof if I'm extremely careful...
Old Jan 6, 2002 | 08:30 AM
Jason's Avatar
you just need to use an open end wrench to stop the gears from spinning when you loosen them...that's the only reason for the wrench...otherwise, you'll be there all day trying to loosen a gear bolt while the cam and bolt are spinning..
it won't slip that easily, if it does, it shouldn't mess anything up unless you have enough power in your arms (which you don't, no offense) to do any kind of damage
think of having your front end up and trying to unbolt the wheel, it spins, same idea...
AssPenny's Avatar
Its pretty fool proof.. just set the cams to tdc, you'll see an arrow on the cam gears. Point them up, break the bolts loose, dont remove them. Then remove the timing belt and then remove the gears (Don't loose the the key). Put the new gears on and tighten them up. Make sure the gears are at top dead center and put the belt back on then torque the bolts to the correct spec. Pretty simple, just take your time. You have a helms manual right?
Old Jan 6, 2002 | 08:35 AM
oryanh's Avatar
Default Re: Pics of cut valve cover? - ok to cut while on the car? (AssPenny)
No Helms here...
I was hoping someone would scan in those pages...
Yeah right, I guess I just need to cough up the 62 bucks.
Old Jan 6, 2002 | 08:40 AM
owen_the_soyboy's Avatar
isnt there a cam how-to at c-speedracing.com or whatever the site is?
Old Jan 6, 2002 | 08:42 AM
Floyd's Avatar
This walkthrough for changing the timing belt will help cover a lot of it.
http://www.c-speedracing.com/howto/t...elt/tbelt.html
Good luck!
-Floyd
Does anyone know of some other sites that have how-to's other than
http://www.c-speedracing.com/howto.html
and
http://www.bseries.net/html/garage/index.php
Old Jan 6, 2002 | 08:43 AM
oryanh's Avatar
Default Re: Pics of cut valve cover? - ok to cut while on the car? (owen_the_soyboy)
It's only for valve cover removal, and timing. -close though.
Old Jan 6, 2002 | 09:48 AM
Jason's Avatar
this will help you out...shows pics and stuff
http://www.c-speedracing.com/howto/caminstall/cam2.html
GrnZ
Apr 10, 2008 11:52 AM
b16bri
Paint and Body
Jan 12, 2008 07:24 PM
BigC-ivic
Aug 3, 2005 08:47 PM
JeremyL
Apr 16, 2003 10:10 PM
Scary1109
Dec 15, 2001 10:00 AM
