D-series tranny q's
Old Jan 6, 2002 | 07:26 AM
eg6ajk's Avatar
Default D-series tranny q's
two questions, if you don't know please do not answer, don't feel like popping open 3x cases just to finout it doesn't fit...
can I swap the 2-5 gears from ZC onto my VTi tranny (same as 92-5 si/EX)
and/or
use the 4.437FDR from the JDM ZXi Teg (d-series tranny) (which uses half shaft) but I don't want to use the whole diff just he FD, so that I can reuse my LSD...
Old Jan 6, 2002 | 07:28 AM
DragII's Avatar
25 Year Member
Default Re: D-series tranny q's (eg6ajk)
sorry I don't know..but I find it very interesting that there is a d series tranny which uses a half shaft
Old Jan 6, 2002 | 08:01 AM
eg6ajk's Avatar
Default Re: D-series tranny q's (AntGonch)
ZC and JDM ZXi L4 trannys uses half shafts as well as 92-5 ZC trannies as well....
the only thing, is that my 1.5l has no provisions for half-shaft installation, otherwise I wouldn't care....
Old Jan 6, 2002 | 10:20 AM
Mista Bone's Avatar
D Tranny Guru
no on the FD swap, L3 shafts are different lengths (1-2 mm shorter)
also second second gear is machined into the mainshaft.
You can use the ZC 3rd with the narrower bearing. To use the ZC 4th it will need to be machined to clear synchro hub. 5th is a straight swap, but really kinda high reving is you do alot of open road driving.
zc 5th about = Si 4th
I suggest a CRX DX/Si 5th gear of .771 as best choice.
Old Jan 6, 2002 | 11:13 AM
eg6ajk's Avatar
Default Re: D-series tranny q's (Mista Bone)
how about swapping complete FD 4.4 diff with ZC gearing onto the S20 casing???
I mean I will most likly upgrade to 1.6l soon...
l8er
adrian
Old Jan 7, 2002 | 05:16 AM
Mista Bone's Avatar
D Tranny Guru
to swap the FD you'd have to swap the countershaftv also, but it is too short to be used.
Only one choice if you want a higher FD, Houseman Autosports, a Canadian also.
Gen4Si
Feb 21, 2005 03:34 AM
sleepingcivic90
49
Jan 21, 2005 09:55 AM
M_L_H
May 24, 2004 04:24 PM
JackAcc
Jul 13, 2003 01:24 PM
