Need help installing piston/rod, how do I install wrist pin?
Old Dec 24, 2004 | 01:21 PM
90teg's Avatar
Default Need help installing piston/rod, how do I install wrist pin?
I've only dealt with arias and je pistons. Those are easy to install on rods cause they have lock rings to hold the wrist pin in place. Well now I'm installing CTR piston on some LS eagle rods. How does the wrist pin stay in place? Am I missing something? I have the pistons, writst pins and rods, but how does the wrist pin not slid out while it's in the engine?
Old Dec 24, 2004 | 02:29 PM
IN VTEC's Avatar
Default Re: Need help installing piston/rod, how do I install wrist pin? (90teg)
Grooves will have to be machined into the PCT piston to accept the wire locks. I would just switch to using a forged piston with the grooves already machined. It'll be a lighter piston anyways for the same dome displacement..
Old Dec 24, 2004 | 03:04 PM
90teg's Avatar
Well I already bought the PCT's. Is there anther way?
Old Dec 24, 2004 | 03:49 PM
HONDABROMANDUDE's Avatar
Default Re: (90teg)
there is no other way to do it if you plan on using the PCT pistons, unless you want to put them on stock ls rods.
Old Dec 24, 2004 | 04:13 PM
Used2beAb16's Avatar
Default Re: (90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg &raquo;</TD></TR><TR><TD CLASS="quote">Well I already bought the PCT's. Is there anther way?</TD></TR></TABLE>
yeah have them machined.
Old Dec 24, 2004 | 06:20 PM
90teg's Avatar
Well I tried searching for lock rings, but I don't know what size pct's would use. Anyone know where or what size lock rings to use?
Old Dec 25, 2004 | 03:40 AM
90teg's Avatar
Anyone?
Old Dec 28, 2004 | 10:33 AM
90teg's Avatar
So installing jdm itr pistons with eagle rods requires the same thing or are the able to be pressed in?
Old Dec 29, 2004 | 07:47 AM
Default Re: (90teg)
same
cobra2326
Mar 18, 2008 06:32 AM
Youlose1305
Jul 1, 2006 09:53 PM
Flexin5
Nov 9, 2005 05:08 PM
h22a193
Dec 14, 2004 12:51 PM
90teg
Aug 1, 2003 11:57 AM
