A'PEXi Power FC
Old Jan 6, 2002 | 01:29 AM
Titanium White's Avatar
Default A'PEXi Power FC
Anyone here running one? I did a search and came up empty. I am about to do an ECU upgrade and seeing the flex ability the Power FC has, seems to be the best bang for the buck. Any input would be greatly appreciated.
Jeremy
[Modified by Titanium White, 4:54 AM 1/6/2002]
Old Jan 6, 2002 | 02:25 AM
sgT's Avatar
sgT
Default Re: A'PEXi Power FC (Titanium White)
Not the greatest as far as aftermarket ECUs go.
I dont like it for 2 reasons:
1. You dont have true control over the maps, only what they call correction maps
which makes it into an oversized VAFC in a way.
2. All programming must be done through a handheld programmer. Very annoying
and you dont get to have a good look at what you are doing.
Also, you will have to find someone nearby who is good at tuning and/or knows
the FC very well.
I recommend the hondata, not only because i am a dealer and use one in my own
car, but because I feel that its much more versatile. The cost is a bit on the high
side for 96+ cars, but its worth it.
one thing i should say, if you dont have plans of doing serious motorwork, your
money is probably better spent elsewhere.
Old Jan 6, 2002 | 12:40 PM
Austin's Avatar
What kind of questions do you have...there are a couple of us on the board that have the PowerFC.
Austin
Old Jan 6, 2002 | 02:34 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: A'PEXi Power FC (Austin)
mine id supposed to arrive on the 8th.can't wait to try it out!
Old Jan 6, 2002 | 06:20 PM
Austin,
I know the Power FC has water temp. correction in the tuning parameters, does that translate into electric fan controller?
Do you have the Power FC commander? If so, is the keypad easy to read & work from?
What type of control do you have over the tuning maps?
Jeremy
Old Jan 6, 2002 | 06:25 PM
NAB20C5's Avatar
[quote]Austin,
[QUOTE]
No
Jeremy
Yes in my opinion and as far as the maps...all I have to say is get some one who knows what they are doing when you have your FC tuned...although it is plug and play...don't play if you have no idea what you are doing....and I like my FC very much...
Old Jan 7, 2002 | 08:49 AM
Austin's Avatar
Default Re: A'PEXi Power FC (NAB20C5)
I think that Eric answered most of your questions...if you have more, please ask. As I've been playing with the PowerFC for about 7 months now, and about 60 dyno runs.
Austin
Old Jan 7, 2002 | 11:03 AM
NAB20C5's Avatar
Austin
Haha....well if I can quit blowing my motor I will make more adequate dyno runs w/ mine so can compare plots w/ Austin
Old Jan 7, 2002 | 11:13 AM
B18CXr's Avatar
keypad is a breeze to work from
Speed Infliction
Aug 19, 2006 01:33 PM
Asahi
10
Feb 1, 2003 02:46 PM
builthatch
Jan 31, 2003 02:38 AM
R3dL1n3
Apr 23, 2002 09:55 AM
MiraiZ
Feb 22, 2002 06:54 AM
