Lightest stock size ITR rotor
Old Dec 24, 2004 | 11:20 AM
EricUSC's Avatar
Default Lightest stock size ITR rotor
Who makes the lightest stock size ITR rotor and how much does it weigh? If you think you have a contender, please post the rotor its the weight.
Old Dec 24, 2004 | 11:22 AM
uNF$@#!'s Avatar
Default Re: Lightest stock size ITR rotor (EricUSC)
if you really are concerned about reducing rotational weight,
cf based rotors is probably your best bet
Old Dec 24, 2004 | 02:00 PM
Bbasso's Avatar
ATS has some sort of rotor... but I don't know the name.
Old Dec 24, 2004 | 03:02 PM
vtecnik's Avatar
if you use the caR at all on the street i would not recomend cf based rotors for the fact that they dont work for **** when they are not hot. so after a nice drive on the freeway you may have trouble slowing down at the off ramp.
Old Dec 24, 2004 | 03:56 PM
1GreyTeg's Avatar
Default Re: Lightest stock size ITR rotor (vtecnik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">ATS has some sort of rotor... but I don't know the name.
Dude that pic is like forever ago, where did you dig it up from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecnik &raquo;</TD></TR><TR><TD CLASS="quote">if you use the caR at all on the street i would not recomend cf based rotors for the fact that they dont work for **** when they are not hot. so after a nice drive on the freeway you may have trouble slowing down at the off ramp.</TD></TR></TABLE>
Bingo!
You don't want CF for this reason just to start, if it sees any street time at all, not to mention prohibitive costs.
Old Dec 24, 2004 | 10:26 PM
EricUSC's Avatar
OK, so what is the lightest non-CF stock size ITR rotor? I want something that is usable on the street.
Old Dec 24, 2004 | 10:47 PM
baonest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC &raquo;</TD></TR><TR><TD CLASS="quote">
OK, so what is the lightest non-CF stock size ITR rotor? I want something that is usable on the street.</TD></TR></TABLE>
stock rotor.
or something like brembo blanks. or autozone rotors.
Old Dec 25, 2004 | 05:54 AM
Dan GSR's Avatar
Default Re: Lightest stock size ITR rotor (baonest)
stock rotor, and cross drill the **** out of them
Old Dec 25, 2004 | 06:06 AM
Dan GSR's Avatar
Default Re: Lightest stock size ITR rotor (Dan GSR)
lightest rotor evARRRRRRRRRRRRRrrrrrrrrr !!!!!!!!1111
acutual weight is less than 1 stock lug nut
now buy some used brake pads, with less than 1mm pad left, and you will have the lightest setup of any R
Old Dec 25, 2004 | 06:40 AM
RTW DC2R's Avatar
why are you so concerned with rotor weight? the differences are probably so marginal you would never even notice the difference, especially on the street. if anything you should be more concerned with the wheel weight. stick with autozone blanks and call it a day.
Old Dec 25, 2004 | 06:55 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC &raquo;</TD></TR><TR><TD CLASS="quote">Who makes the lightest stock size ITR rotor and how much does it weigh? If you think you have a contender, please post the rotor its the weight.</TD></TR></TABLE>
I think you're barking up the wrong tree, if you don't mind my saying so.
I'm not sure what you have in mind, but most of us would consider brake rotors a very expendable item and some of us go through a couple of sets per year on the front.
To spend money trying to save weight on rotors would be very expensive if done logically and well, and without your saying what you have in mind with this project, I think that most of us would tell you to forget about it.
Remember, too, that with conventional steel rotors, if you reduce the mass of the rotor you are also reducing the thermal efficiency of the rotors.
There are quite a few experienced ITR users who go with <u>heavier</u> Legend rotors to get better wear and thermal dissipation.
Old Dec 25, 2004 | 07:19 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">lightest rotor evARRRRRRRRRRRRRrrrrrrrrr !!!!!!!!1111
F***ing awesome Dan. Now all I need are helium-filled tires and I'm set! Where can I get those?!?!
(p.s. crossdrilled thumb was a nice touch)
Old Dec 25, 2004 | 07:21 AM
Chris F's Avatar
Default Re: Lightest stock size ITR rotor (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, if you're looking to lighten something, go after the calipers, wheels or tires. Rotors are a saftey item IMO and lightening makes them less efficient/weaker.
What are you using the rotors for?
-Chris
Old Dec 25, 2004 | 07:26 AM
RTW DC2R's Avatar
Default Re: Lightest stock size ITR rotor (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
stopping
Old Dec 25, 2004 | 07:28 AM
Chris F's Avatar
Default Re: Lightest stock size ITR rotor (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
stopping </TD></TR></TABLE>
[e] Edited to protect the guilty.
Modified by Chris F at 7:51 PM 12/25/2004
Old Dec 25, 2004 | 09:03 AM
Todd00's Avatar
I said I don't want a title!
Aluminum hat rotors (2 piece). Way lighter than the oem blanks. Good luck finding a set though.
Old Dec 25, 2004 | 11:55 AM
EricUSC's Avatar
Default Re: Lightest stock size ITR rotor (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Aluminum hat rotors (2 piece). Way lighter than the oem blanks. Good luck finding a set though.</TD></TR></TABLE>
2-piece rotors are definately lighter than stock rotors, but who makes them for the ITR in stock size? I know Stop Tech did, but they got discontinued. Project Mu makes them, but they are very expensive. If you guys know anybody else that makes 2-piece rotors, please post.
Old Dec 25, 2004 | 01:58 PM
.RJ's Avatar
.RJ
Why do you want lighter rotors? You're chasing your tail... there is ~110lbs of unspring weight at each front corner. Lighter rotors = more prone to brake fade.
Old Dec 25, 2004 | 03:08 PM
uNF$@#!'s Avatar
lol dan.... you weight reduced his fingers too
Old Dec 27, 2004 | 01:49 PM
GPNY's Avatar
Default Re: Lightest stock size ITR rotor (255.255.255.255)
Fastbrakes made some a while back. He said he would not make them again unless they were all paid for up front.
See if you can get a group buy going...
Weel
18
Oct 21, 2010 05:18 PM
boostinb20vtec
Jun 6, 2005 11:48 AM
Rick Solis
Apr 25, 2004 10:52 AM
EXspeedyaDOTCOM
Dec 11, 2003 08:19 PM
