stock intake resonator
Old Dec 24, 2004 | 10:42 AM
rmiles87's Avatar
Default stock intake resonator
should i take it out when i install a short ram intake?
and also how the hell do you do it?
Old Dec 24, 2004 | 10:44 AM
ralphie14's Avatar
Default Re: stock intake resonator (rmiles87)
Yeah you take it out there is no need for it with a short ram as far as I know. To take it out you just undo all the bolts and it comes out. Go get a Helms or other manual from the library if you need to know where all the connections are.
Old Dec 24, 2004 | 12:17 PM
Dstretch33's Avatar
Default Re: stock intake resonator (ralphie14)
you don't have to take it out, its not doing any thing sitting in its factory position. If you want to make your engine bay look clean take it out. It will require you to take off your front bumper, then slide it down. Or you can get a saw and cut it in half, thats what we did when I had my 99 mrp em1.
Old Dec 24, 2004 | 12:27 PM
93egSIboi's Avatar
Default Re: stock intake resonator (Dstretch33)
I didn't do any cutting when i took my stock intake out. What i did was just jack the front end up a bit and wiggled the peice out the bottom. Peice of cake and only took a couple minutes. No need to remove the bumper.
Old Dec 24, 2004 | 02:11 PM
Dstretch33's Avatar
Default Re: stock intake resonator (93egSIboi)
when i had my 99 si if i recall correctly the u shaped resonator was caught on something. So instead of jacking up the car we just cut a portion of it off, and pulled it out.--your right I don't think we took the bumper off for that, none the less the bumper was off during the install--
ribal_gh
Sep 19, 2012 07:16 AM
civicSF98
25
Mar 5, 2010 05:41 PM
wegotmorrison
Jul 14, 2007 03:06 PM
SE7EN3S
Feb 25, 2002 03:11 PM
Speed_Ricer99
Feb 15, 2002 08:58 AM
