Power Window Problem :o
From: Your mommas bed, that might be true too ..., So Cali, USA
a kin of mine had tried to install integra panels in his 95 coupe and plugged the integra window switch into the civic window switch socket but they didnt work then he plugged the civic window switch back in now his windows dont go down ? whats up and how can this problem be solved or will it be on unsolved mysteries LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Star »</TD></TR><TR><TD CLASS="quote">maybe check the fuses?</TD></TR></TABLE>h
have you checked these yet??
From: Why so you can pretend like youre interested, FL/OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch »</TD></TR><TR><TD CLASS="quote">make sure that both sides are plugged in, if one side is not connected, then the windows will not work</TD></TR></TABLE>
That's only true in reference to the driver side since it has the master switch. If the passenger is not connected, the driver side will still operate fine. If there was no wiring, splicing involved, then I advise checking fuses, that is the only thing it could be beyond a faulty wiring/plug.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
If the stock switch doesn't work now and it isn't a fuse and wires are fine, he might have burnt the motor. Just a highly unlikely but unmentioned poss.
91integraLSVTEC
May 10, 2005 01:15 PM
