Accord Injectors same as LS injectors?
Hey guys,
I have some extra accord injectors sitting here and I'm needing to get my injectors for my LS build cleaned/blueprinted, and I was thinking if the Accord ones are the same as the Integra ones, then I wouldn't have to worry about any down time and just get the Accord ones done and put them in when I swap intake manifolds on the B18B1.
Are they the same size and everything else? I would assume so. I know they fit, but flow wise are they also 240cc (I believe stock rating for the ls injectors), and electrically, etc the same?
- Nathan
- Nathan
97 and older Accord injectors might not work, they use peak and hold, unless you use injector box. I had to modify the inside of the plug, it had an extra line inside of it. I finally found out that it was peak and hold when I used a multimeter to test the ohm reading. Turned out it read between 3 ohm - 1 ohm. Saturated injectors read 16 ohm - 12 ohm. It ran but I'm afraid to rev it because I had no injector box. This could burn up you ecu if you don't get one.
Modified by lek9l at 2:29 AM 9/15/2008
jmal1919
Sep 12, 2003 11:49 AM
