02 f23a1 Accord Injectors Saturated or Peak n Hold
Simple question
Does the 02 accord use saturated injectors or peak n hold injectors? Going to buy some 440's tomorrow and need to know which one's to get so that I don't need a resistor box.
Re: 02 f23a1 Accord Injectors Saturated or Peak n Hold (jmal1919)
To make sure get a multimeter, and measure the voltage drop across the injector. You'll know the voltage and current from the controller with the resistance will be unknown. Use kirchoff's voltage law:
Voltage=Resistance x Current
Just solve for resistance you you'll have your answer in Ohm's. 3-5 ohms=low impedance, 10-12 ohms=high impedance.
don't have access to a multimeter and no shop will let me use one temporarly so I just called RC and confirmed that I do need saturated injectors.
nice info though.
nice info though.
NathanMorris
09-14-2008 11:06 PM
