what all does it take to make a vtec head work on a crx
Old Dec 23, 2004 | 03:45 PM
crx_of_fury's Avatar
Default vtec head work on a crx with d16y7 block????? easy??
i wanna buy everything and get it done in one day. is that possible
Old Dec 23, 2004 | 04:37 PM
doublethink's Avatar
Default Re: vtec head work on a crx with d16y7 block????? easy?? (crx_of_fury)
short version: you need a newer d series head and convert to obd1.
long version: go to search, and "mini me" with archive content checked.
Old Dec 23, 2004 | 04:45 PM
CRX_Control's Avatar
Default Re: vtec head work on a crx with d16y7 block????? easy?? (doublethink)
get z6 or y8 or jdm vtec sohc head, then remove the oil jet from the engine you want to put the head on , then install it , then convert obd1 with harness(easy way) then get p28 ecu(good ecu) and wire up vtec, then you should be finished.
Old Dec 23, 2004 | 06:47 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">go to search</TD></TR></TABLE>
mrporte
Oct 3, 2007 03:45 AM
gophat
Sep 11, 2006 06:29 AM
ILcrxsi1
Jul 8, 2006 04:49 PM
beatthisspeed69
Mar 24, 2006 12:59 PM
itsmebeaner1987
Oct 17, 2004 07:30 AM
