creaking suspension on a '96 LX sedan
Old Dec 23, 2004 | 03:40 PM
buzzboy8's Avatar
Default creaking suspension on a '96 LX sedan
I drive a '96 Accord LX sedan, and have been experiencing suspension creaks. My first instinct was that my shocks were blown (stock shocks/springs), but upon doing a simple "bounce each corner of the car" test, I found that only my left rear shock is blown. My suspension creaks pretty loudly, mostly when im going over speed bumps or other large bumps at low speeds. At first it was only the rear suspension, but pretty soon it was the front, too. What could be the problem?
Old Dec 23, 2004 | 04:49 PM
BaGGed HoNDa's Avatar
dry weather will wear out your suspension bushings often times. i live in central oregon and on a dirt road so mine are drying out also. what i would reccomend doing is just going to a local suspension shop, or tire shop or whatever you have and ask them about a full poly urethane bushing kit, should only cost about 150 for the kit but expect another 250 or so for the labor.
Old Dec 25, 2004 | 10:44 AM
buzzboy8's Avatar
Default Re: (BaGGed HoNDa)
i'm not so sure about that, because i live in north carolina, where not only is it often rainy, but also extremely humid throughout the year. i doubt dryness is the problem, although it is possible.
Old Dec 25, 2004 | 10:57 AM
jdmaccord23's Avatar
Default Re: (buzzboy8)
I have a 97 DX and I'm starting to experience a similar problem. Your bushings probably need to be replaced. If your car is lowered and you've got camber kits check to see if they're dried out and need litheum grease.
Old Dec 25, 2004 | 11:57 AM
Toldge's Avatar
Default Re: (jdmaccord23)
i'm about to change out my struts
I have the same creak sound you do whenever i go over speed bumps, potholes, etc
I will try these bushings in about a week when I install the new struts
http://cgi.ebay.com/ebaymotors...=WD1V
99tegjawn
Suspension & Brakes
Apr 30, 2011 08:31 AM
maal15
Nov 7, 2008 08:23 AM
onlyinmydreams
May 10, 2006 08:32 PM
