OT: anyone figure out how to keep water out of tailight's?
a couple months ago i bought a set of jdm 98+ tailights from passwordjdm..
even before i installed them the passenger tailight had water in it..
hoping the new lights wouldn't do that but same thing w/ the passenger light.
anyone know how to solve this?
when i got the lights, they were in perfect condition..i always inspect used parts..
i took the lights out a few hours ago and just cant seem to find the leak. also when i installed the jdm 98+ lights i took the stock gaskets off the 01 lights..but no luck ill try the silicone ...thanks
anyone else?
anyone else?
This thread was just in the Integra forum. Not sure if it'll solve the problem, but who knows. https://honda-tech.com/zerothread?id=1086869
Good luck on finding the leak
Works even better on fogged up headlights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K »</TD></TR><TR><TD CLASS="quote">where did you learn that trick? interesting.
sucka
sucka
as long as the tail light assembly itself is not cracked, or have a hole
replacing the tail light gasket, will solve your water accumulation problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">as long as the tail light assembly itself is not cracked, or have a hole
replacing the tail light gasket, will solve your water accumulation problem</TD></TR></TABLE>
thanks for the tip.......
i realize that honda calls them "gaskets", but in reality they are just dampers, not gaskets. the purpose of them is to stop vibration or noise, not water leaks. if you have a water leak, bottom line is.. you have a hairline crack, or the seal where they joined the 2 pieces together is faulty.
don't believe me, ask honda.
have first hand experience?
because I do
I have an older integra, and the neoprene gasket, became old and flat
I bought new gaskets and no longer have water in the tail lights, and trunk
because I do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenr#1011 »</TD></TR><TR><TD CLASS="quote"> a couple months ago i bought a set of jdm 98+ tailights from passwordjdm..
</TD></TR></TABLE>dont drive in the rain
j/k
j/k
i dont know...i will get some new gaskets(dampers) and see how that works...i took the light out, tried prying the actual plastic on the outside but i couldn't get it off. cuz i didnt wanna break it.. i can think of worse things that have happened to #1011..just look out for ladys in white maximas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r573 »</TD></TR><TR><TD CLASS="quote">dont drive in the rain
j/k</TD></TR></TABLE>
hey thats fine with me... that means the r will always be clean
j/k</TD></TR></TABLE>hey thats fine with me... that means the r will always be clean
</TD></TR></TABLE>Not really she will get dusty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r573 »</TD></TR><TR><TD CLASS="quote">Not really she will get dusty.</TD></TR></TABLE>
thats what 8400rpm is for..just to blow it off
besides im tired of water going into the twin loop
AllCityNemo
May 10, 2009 07:02 AM
