questions on Turbos and Ignition timing
Old Jan 5, 2002 | 09:29 PM
Veil_Side_'s Avatar
Default questions on Turbos and Ignition timing
Okay I've seen and learned about most of the mods out there but I am just beginning to touch the idea of Turbo's and Ignition timing advance. First of all. If I advance my ignition timing, how much of an increase in HP could I expect. Second, for Turbo's, do I have to adjust timing just like when using N20?
Old Jan 6, 2002 | 12:30 AM
rainforest's Avatar
Default Re: questions on Turbos and Ignition timing (Veil_Side_)
well advancing the timing will lean your air/fuel ratio out and in case give you power. but if you want to run safer retard the timing and run more fuel or safer
video_voide
Engine Management and Tuning
11
Feb 22, 2013 11:48 AM
mortificationrock
Jul 10, 2007 04:26 PM
DEMNTD1
Jun 28, 2005 05:19 PM
