I need help diagnosing this problem
Old Dec 23, 2004 | 01:17 PM
buzzboy8's Avatar
Default I need help diagnosing this problem
I have a '96 Accord LX sedan, and it has some kind of engine gremlin going on right now. It doesn't run funny or anything, but gas mileage has been decreasing a bit lately. Anyway, here's the problem: I pulled out one of the spark plug wires (second one from the right, when you are facing the engine bay), and the plastic part that connects to the plug was covered in oil. I idled the car with the oil cap open, and it exhibits no signs of excessive blowby; I have been checking the oil levels frequently, and there is no sign of a leak or oil consumption. After wiping off the plug wire and cleaning out the oil from the area around the plug, the oil will repeatedly reaccumulate. What could be going on with my car?
Old Dec 23, 2004 | 01:25 PM
bill-71SS's Avatar
Default Re: I need help diagnosing this problem (buzzboy869)
you neeed to replace the valve cover gasket and plug tube seals
Old Dec 23, 2004 | 04:52 PM
BaGGed HoNDa's Avatar
Default Re: I need help diagnosing this problem (bill-71SS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bill-71SS &raquo;</TD></TR><TR><TD CLASS="quote">you neeed to replace the valve cover gasket and plug tube seals</TD></TR></TABLE>
Yep, thats what you gotta do. The same thing happend to my Integra.
Old Dec 23, 2004 | 06:00 PM
buzzboy8's Avatar
thanks. replacing the valve cover gasket is easy enough, but what do i need to do to replace the plug tube seals? does that require pulling the head? or can i do it with just the valve cover off?
Old Dec 23, 2004 | 06:12 PM
All you need to do is pull the valve cover off. The seals are at the top of the spart plug tubes and butt up against the tube and the valve cover. They will usualy come with the valve cover gasket.
Old Dec 24, 2004 | 05:23 AM
Honda Bob43's Avatar
Default Re: I need help diagnosing this problem (buzzboy8)
if the problem is still there after you replace the upper tube seals you will need to replace the lower tube seals.
I dont think thats causing you fuel problem b/c you say the engine is running fine.
simplist things first. start with tire pressure
Old Dec 25, 2004 | 11:03 AM
buzzboy8's Avatar
Default Re: I need help diagnosing this problem (Honda Bob43)
i found spark plug seals on manchester honda's website. http://www.manhonda.com/ap/ind...pid=9
are these the the proper part for replacing my leaky plug tube seals?
Old Dec 27, 2004 | 03:48 PM
spooned out's Avatar
hey ...u are going to need new spark plug seals..by changin it u have to take off ur valve cover..cuzz the seal is on the inside of ur valve cover...the seal is plastic so after time it starts to get hard from age and heat...wich will leak oil onto ur spark plugs...try that...''spark plug seals''theres 4 of them..i recomend changin valve cover gasket dince u have the valve cover off anyways...if it hasnt been changed yet.......
SeanaK
Jun 24, 2014 03:22 PM
SeanaK
Engine Management and Tuning
10
Jun 22, 2011 09:18 AM
91lsteg
Dec 1, 2004 09:36 AM
hYpE-R-29
May 13, 2003 06:16 PM
briq4
Aug 8, 2001 04:47 AM
