Decent turbo setup
Old Dec 23, 2004 | 12:32 PM
91_Model X's Avatar
Default Decent turbo setup
Hello. Ok, first of all, I have a 1991 CRX DX converted to MPFI, with a few bolt on mods. (Everything else internally is stock). I have been doing a lot of research on turbos, etc. I want to go a fairly cheap route. Although, I want to get a nice turbo manifold, and bolt a used turbo to it. Is there anything else I need to consider? Do I still have to use larger injectors? And as far as management goes, what would I need? (just something basic, and not too expensive). I would only be running around 6-7psi of boost. (probably).
Hehe, it's kindof funny, my brother has an '86 Acura Legend(v6, all stock), and he can still beat me in a drag race, I got him off the line, (he has an automatic) but then, to my dismay, he zooms pass me.
So, a simple turbo setup, for some nice power, and so I can beat him! Well, thanks in advance.
-Jake
Old Dec 23, 2004 | 12:38 PM
CRX_1.8T's Avatar
Default Re: Decent turbo setup (91_Model X)
Hey welcome to Honda Tech.
Well, as for the turbo questions, you may want to just wait until you can post in the forced induction area OR try using the search thing on the top right hand corner of your screen. There is a few years worth of stuff all archived in there for you to research, it is very helpful.
Good luck!
Old Dec 23, 2004 | 02:19 PM
GoFastMotorSports's Avatar
Default Re: Decent turbo setup (CRX_1.8T)
for a good manifold go to http://www.spoolinperformance.com
Old Dec 23, 2004 | 02:24 PM
amh0001's Avatar
Default Re: Decent turbo setup (GoFastMotorSports)
http://www.homemadeturbo.com
http://www.turbod16.com
these two sites will be your new best friends, read up!
and good luck, we want numbers and pictures when your done
~AMH
Old Dec 23, 2004 | 02:26 PM
Default Re: Decent turbo setup (amh0001)
turbo d16 is great... But what happened??? I guess they got hacked or some ****. That sucks cause I wanted to buy something from somebody off there but they have been down for like 5 days rite now
Old Dec 23, 2004 | 06:00 PM
The Clash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_Model X &raquo;</TD></TR><TR><TD CLASS="quote">I have been doing a lot of research on turbos, etc. I want to go a fairly cheap route. Although, I want to get a nice turbo manifold, and bolt a used turbo to it.</TD></TR></TABLE>
Nice and cheap is hard unless you get a good deal or used one. I'm not sure what you're idea of nice is, but if it's a quality tubular design manifold then you'll be looking at about $500+ and even a good cast manifold will be $300+. An SS Autochrome mani or a STD/HF manifold would be the best bang for the buck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Is there anything else I need to consider?</TD></TR></TABLE>
There's quite a lot to consider when forcing air into you motor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Do I still have to use larger injectors?</TD></TR></TABLE>
Technically no, but honestly if you plan to do it right you will need larger injectors and a high flow fuel pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And as far as management goes, what would I need? (just something basic, and not too expensive). I would only be running around 6-7psi of boost. (probably).</TD></TR></TABLE>
An FMU will do the trick to get you up and running, a VAFC/SAFC with 450 DSM injectors and hack is a little better, then of course you could get your ECU socketed and run some D.I.Y. Hondata style tuning like Uberdata, Turbo Edit, Ghettodyne, etc.
Old Dec 23, 2004 | 06:31 PM
Default Re: Decent turbo setup (The Clash)
Save your motor,dont do the AFC hack.
druidesque
Apr 19, 2010 09:56 AM
hybrid90
Feb 26, 2008 01:45 PM
91_Model X
Dec 23, 2004 04:26 PM
