00 Accord Special Edition Breaking down?? HELP!!
i have a 00 accord special edition and recently everytime i brake i hear the left front grind..and now there's a fluid leaking from it..i don't think it's my brake pad..could it be my rotor or brake fluid leaking??..please help??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chitowntiger »</TD></TR><TR><TD CLASS="quote">how do i check the brake fluid??</TD></TR></TABLE>
you probably need to bring the car outside to have the mechanic to check it.
i am assuming you don't know a whole lot about car.
check with your owner's manual for more info.
RED oil- Automatic trans oil
Brownish oil-motor oil OR dirty brake oil
clear/light tea color=power steering
chances are u need brakes... if it sounds like metal 2 metal grinding...the pads are gones...if the pads are gone u goin to need brakes and rotors...also if u running low on fluid..check master cylinder.. maybe leaking brake fluid...cuzz if its leaking...u mite not have any brakes at all..be kinda scarey coming to a red light one day and no brakes...right..
david
Oct 31, 2005 11:02 AM
