Shift Linkage Help For CRVTEC Into 87 CRX Si?
I know HASport has a premade one, but what would be an easy, effective (and cheaper) way to do it?
For those of you who have not figured out, such a swap ends up being kind of expensive if you want to "dot the I's and X the T's"....
I think you just need to change the length of the two rods. According to SCC's article on putting the B16 in an '86 CRX (11/01), the shift rod needs to be 0.25" longer and the torque rod 0.5". Apparently you use '86-'89 Integra rods, not Civic/CRX rods.
You can also modify the CRX linkage. The article only mentions the Integra linkage, because that is what we sell, lengthened NEW Integra linkage.
The CRX linkage just needs to be lengthened more, it works just as well.
brian g
brian g
streetsold6teeny8
18
Jun 29, 2009 10:18 PM
