USDM ITR axles the same as all other bseries axles?
Old Dec 23, 2004 | 10:42 AM
dunkd's Avatar
Default USDM ITR axles the same as all other bseries axles?
talking about the 32mm usdm itr axles. Is everything else identical to lets say GSR or B16 axles? thickness of the shaft? i know that the abs ring would be different between abs/nonabs cars.
Old Dec 23, 2004 | 10:50 AM
99 TYPE R's Avatar
They say Gsr axles are a lil stronger, but i used almost every stock replacement axle u can buy and have had not alot of problems. Iwould say as a replacement axle no. Everything should be identical, at least to my knowledge.
Old Dec 23, 2004 | 10:52 AM
dunkd's Avatar
why would that be though if they are structurally identical?
Old Dec 23, 2004 | 10:53 AM
99 TYPE R's Avatar
Default Re: (dunkd)
The internals could be made atronger for the 1.8's beacause of more power but id doubt it.
Old Dec 23, 2004 | 12:21 PM
sackdz's Avatar
Default Re: USDM ITR axles the same as all other bseries axles? (dunkd)
Pretty sure there are 2 sizes of bseries axles, 32mm and 36mm. The 36mm came on some JDM models.
Old Apr 15, 2005 | 03:47 PM
Tommy_Gunns's Avatar
Default Re: USDM ITR axles the same as all other bseries axles? (sackdz)
So, if I were to get B16A axles from a Del Sol VTEC or Civic SiR, it would work on my ITR with no problems?
Old Apr 15, 2005 | 04:01 PM
Kendall's Avatar
Default Re: USDM ITR axles the same as all other bseries axles? (Tommy_Gunns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy_Gunns &raquo;</TD></TR><TR><TD CLASS="quote">So, if I were to get B16A axles from a Del Sol VTEC or Civic SiR, it would work on my ITR with no problems?</TD></TR></TABLE>
Yep.
Old Apr 15, 2005 | 09:38 PM
t0ekn3e's Avatar
yessur
Old Apr 15, 2005 | 09:41 PM
92TypeR's Avatar
FSAE
Default Re: (t0ekn3e)
There are ABS and non-ABS axles however. You can use ABS axles on non-ABS cars, but ABS will not function if you use non-ABS axles on ABS cars. Does not affect anything else, they just do not have the leads for the ABS sensors.
cBrown05
Oct 5, 2008 12:21 PM
slow_db7
Apr 11, 2008 12:37 AM
NA425DragSter
Northwest (Sales)
Jul 30, 2007 03:51 PM
turkdog
Nov 27, 2003 04:05 PM
austrian type-R
Jun 30, 2003 10:34 AM
