Tein SS coilover question
Old Dec 23, 2004 | 07:55 AM
EMphaticONE's Avatar
Default Tein SS coilover question
Is it possible to take off and/or put on a new adjustment screw/hat on the damper if its missing? for example, can i take off one adjustment **** and put it on another to temporarily set the damper until i can get a new one?
Old Dec 23, 2004 | 08:49 AM
Black HB's Avatar
Default Re: Tein SS coilover question (pearlblueb16)
You could use an alen key if you wanted, just stick it on the top of one with the adjusting **** so you can determine how many degrees turned is equal to a "click". I did it when i broke an adjusting **** waiting for my replacement and it worked fine.
Old Dec 23, 2004 | 08:52 AM
Default Re: Tein SS coilover question (Black HB)
so youre saying that it wont click without the adjustment **** being on there?
Old Dec 23, 2004 | 08:55 AM
Black HB's Avatar
yes, it wont click. the clicking is coming from the ****/hat there are little holes and a bump on the bottom of the **** so when you turn it it "clicks" into the next slot.
Hope these pics help if your trying to remove it, they were for when i broke mine off after it seized but replaced them and worked fine
Old Dec 23, 2004 | 09:21 AM
thanks a lot for the pictures and info; really appreciate it. how much were you charged for the replacement part? also, what damper settings are you using for the front and back?
k3nnex
Suspension & Brakes
Jun 27, 2009 08:12 AM
jeremyrocksursox
Apr 3, 2009 06:30 AM
06SI=superior
Honda Civic (2006 - 2015)
Mar 26, 2007 01:33 PM
DeDonDeRosa
May 15, 2003 05:32 PM
