help me please!!!! itr swap in a 90 integra fuel injectors not working
Old Dec 22, 2004 | 10:21 PM
QUESTOYZ by RHanDy's Avatar
Default help me please!!!! itr swap in a 90 integra fuel injectors not working
hello fellow enthusiats i had just done a 97 itr swap in my 90 integra converted from obd0 to obd1 but for some reason the fuel injectors are not responding which caused the injectors to be still as a result not firing fuel into the fuel rail. i used a test light to see if the injectors were grounded and it seems that both injector wires were a positive charge cam anyone help....am i missing something maybe something careless. any help will greatly appreciated..............if any one can help in my sucess i will paint your car.................free!!! courtesy of "QST" autowerx.
Old Dec 23, 2004 | 01:02 AM
kewbee7's Avatar
Default Re: help me please!!!! itr swap in a 90 integra fuel injectors not working (autopilots)
so you converted your body harness to obd1?? and you took out the resister pack? check your fuses. what sounds does it make when you try to turn it on. does it crank over??
Old Dec 23, 2004 | 10:18 AM
Default Re: help me please!!!! itr swap in a 90 integra fuel injectors not working (kewbee7)
actually i used a jumper harness from obd0 to obd1......the resistor is still the obdo when i crank the car it cranks but wont turn over..............thanx i really appreciate your help......also i hear muffling sound from the tail pipe.......
Old Dec 28, 2004 | 11:27 PM
fourthgenhatchB17's Avatar
Did u fix the problem? What injectors (as in obd) are u running?
John The G
Jun 16, 2011 09:47 AM
contentious
11
Oct 28, 2005 12:04 PM
e jay one
Sep 10, 2005 11:31 AM
sparcob17a1
May 12, 2004 12:18 PM
allmotor.net
Aug 21, 2003 02:47 AM
