check this out
Old Dec 22, 2004 | 09:36 PM
albert's Avatar
Default check this out
whats this motor capible of doing?? 1/4 mile and dyno?
make me an offer on this
got about 4000 mile on it
B18 block
B16a Head
Eagle H-Beam Rods
CTR piston
Arp rod bolt
Block Guard Weldon and resurface
Rotate Assembly
Unthordox lightweight flywheel
everything do at the machine shop
the motor is 12.1 CR . the motor is complete come with the harness and the ecu (ecu been tune for this motor
Old Dec 22, 2004 | 11:40 PM
h22blazerz5's Avatar
Default Re: check this out (albert)
tuned with i/h/e i would say 13s with a hatch and good tires and wheels
Old Dec 22, 2004 | 11:44 PM
Default Re: check this out (d17a turbo)
btw what ecu will u be using and what r u gonna use for tuning uberdata?
Old Dec 22, 2004 | 11:53 PM
albert's Avatar
well I'm thinking about buying this motor for my eg hatch he said it was a tuned ecu
Old Dec 23, 2004 | 01:48 AM
OLM-02R's Avatar
have you dyno tuned it ?? and are you sure that ur cr is 12:1 with ctr piston on b18/b16 ??
Old Dec 23, 2004 | 01:50 AM
albert's Avatar
Default Re: (OLM-02R)
well I copied and pasted what he pmed me on another page as seen above.So no I havent tuned it I'm wnting to buy it from him what can I do to make sure the motor is strong(compression check)?????????????/
Old Dec 23, 2004 | 03:53 AM
hype r 555's Avatar
Default Re: (albert)
comp. test / leakdown test ..... and i had the same setup (pistons & rods) -b18c5 with ctr pistons and eagle i beams and 12.1 sounds about right
Old Dec 23, 2004 | 04:17 AM
Lip's Avatar
Lip
https://honda-tech.com/zerothread?id=854145
eka11day
33
Mar 25, 2011 04:51 AM
Teamdiesel
Apr 7, 2008 05:47 PM
StRoKeD-B16bEj2
Jun 18, 2006 08:27 PM
SirTobywun
Mar 13, 2006 10:30 PM
