gsr dual bend shifter on eg
Old Dec 22, 2004 | 07:50 PM
slammeddelsol95's Avatar
Default gsr dual bend shifter on eg
this is up for my buddy he wants to know how to install a gsr dual bend shifter on a eg coupe the bottom of the shifter is wider then the stock shifter so what do i do
Old Dec 22, 2004 | 07:53 PM
cxSHOE's Avatar
Default Re: gsr dual bend shifter on eg (slammeddelsol95)
just bend the opening on the shift linkage.. and search its been done before...
done..
Old Dec 23, 2004 | 09:24 AM
brockscivic's Avatar
Default Re: gsr dual bend shifter on eg (cxSHOE)
I did this swap 2 weeks ago.... here is what you need to do
measure the Integra shifter with the Civic shifter and mark how much you need to take off. ( should only be on one side because one is longer than the other)
Then, you use a cutting tool ( dremel, hacksaw, die grinder, etc) and make your cut.
After, this use a sanding disk ( goes into drill) or a grinder to smooth out the cut.
Install civic shifter bearing into shifter and re-install
hope this helps....i need to make a write-up on that
Old Dec 23, 2004 | 09:25 AM
BauleyCivic's Avatar
Risky Business
Default Re: gsr dual bend shifter on eg (brockscivic)
I had to bend out the ends of the linkage to accomodate it...I don't recommend it.
Old Dec 23, 2004 | 09:41 AM
Default Re: gsr dual bend shifter on eg (BauleyCivic)
yea Bauley is right, if you dont want to cut and grind..you have to bend the linkage out which i dont recomend...tell your friend to cut it and grind it ( took me 10 mins) its alot easier
gameknb
Jun 11, 2005 07:32 AM
pgpunkguy
Sep 12, 2004 03:56 PM
evilcivilian
Jun 25, 2004 02:23 AM
bullseye
Mar 27, 2004 10:40 PM
ArchAngel Sabastian
Feb 2, 2002 12:09 PM
