missed a gear.... compression test results
Old Dec 22, 2004 | 03:19 PM
hondaeg8's Avatar
Default missed a gear.... compression test results
i missed a gear yesterday and the car over reved. it was the first time i have ever done that to this motor. i guess i shouldn't be playing around anymore.
anyways...i was a little worried cause my rpms went above 9k on a stock bottom jdm gsr motor. when i got home, the car wasn't acting any different and it drove home just fine. idle was still the same, idling at 1k and no idle jumping around. temp stayed the same as usual, no smoke out the exhaust, no knocking, oil pressure was reding perfect at idle.
i went a head and did a compression test today and i got 210 across the board.
so everything should be fine right? is there anything else i should do?
thanks
Old Dec 22, 2004 | 03:34 PM
b18c1bomex's Avatar
Default Re: missed a gear.... compression test results (hondaeg8)
should be just fine
Old Dec 22, 2004 | 04:23 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: missed a gear.... compression test results (b18c1bomex)
you're fine, you'd know if something bad had happened by now but you've certainly checked all the other things that you would have needed to check.
Old Dec 22, 2004 | 04:39 PM
vietshorty's Avatar
You will be just fine.
Old Dec 22, 2004 | 04:42 PM
GdmLaz's Avatar
9k on a stock gsr motor is nothing out of the world
Old Dec 22, 2004 | 04:49 PM
Revolver's Avatar
Default Re: (Slammed92hbonN20)
Yeah, sounds like it's good to me. You shouldnt run into any problems. It's not like it's a normal thing, just once shouldnt hurt it.
Old Dec 22, 2004 | 08:11 PM
hondaeg8's Avatar
Default Re: (Revolver)
yeah...we'll i think it did hit 10k ................... damn chipped ecu
Old Dec 22, 2004 | 09:30 PM
SC0TT's Avatar
10k from 9k is a huge jump...damage wise.
But it sounds like youre alright...watch for smoke.
Old Dec 22, 2004 | 09:51 PM
pwrofdrm's Avatar
Default Re: (SC0TT)
Watch for smoke and get rid of that ECU if you don't need it
Old Dec 23, 2004 | 12:23 AM
hondaeg8's Avatar
Default Re: (lax1185)
i need the ecu
Old Dec 23, 2004 | 06:57 AM
hayabusa160's Avatar
you can do a valve adjustment and check the clerance incase they went out of spec from the over rev
Old Dec 23, 2004 | 07:25 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: missed a gear.... compression test results (hayabusa160)
When I had tranny issues before somtimes it'd lock me out of third gear totally at random and I'd easily hit over 9500rpm on a 1005 bone stock B18C5 engine - still runs absolutely perfectly after 3.5-4 years of hard driving and misshifts.
I can't explain why some people get lucky numerous times and others blow **** up their first mistake.
Also mechanical overevs as in grabbing the wrong gear are what really destroy ****. Mis-shifts are not as bad because there's not much load to it like when shifting say, from 3rd back into second when you meant to grab 4th gear.
Old Dec 23, 2004 | 07:28 AM
jdmjade's Avatar
if you dont here any knocking from the motor, its fine. Knocking noise usually comes from the head.
Old Dec 23, 2004 | 09:05 AM
hondaeg8's Avatar
Default Re: missed a gear.... compression test results (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">When I had tranny issues before somtimes it'd lock me out of third gear totally at random and I'd easily hit over 9500rpm on a 1005 bone stock B18C5 engine - still runs absolutely perfectly after 3.5-4 years of hard driving and misshifts.
Also mechanical overevs as in grabbing the wrong gear are what really destroy ****. Mis-shifts are not as bad because there's not much load to it like when shifting say, from 3rd back into second when you meant to grab 4th gear.</TD></TR></TABLE>
yeah...i didn't drop it down to the wrong gear, just didn't get it into the gear i was going to.
my friend mis shifted his itr motor like 6 times before something happened to his motor.
94typeR
Jun 24, 2007 06:08 PM
xvietxkhmerxboix
Mar 3, 2006 03:05 PM
hondaeg8
22
Jan 6, 2005 07:37 AM
Conechaser
Mar 26, 2002 03:57 PM
98lude
Jul 27, 2001 07:29 PM
