Newbie B16 motor owner
Old Dec 22, 2004 | 02:56 PM
Solscud007's Avatar
Default Newbie B16 motor owner
I wasnt sure where to look under the search feature to narrow down my vague questions.
What parts are swapable between Type R B18 and a normal B16? Will the headers fit? I think the head will fit right? what about IM? thanks for bearing with me. Oh will ITR psitons go into a B16A?
Old Dec 22, 2004 | 03:01 PM
99-DC2's Avatar
Default Re: Newbie B16 motor owner (Solscud007)
the header, pistons, IM, and head are switchable, keep in mind ITR pistons will lower CR on a B16
Old Dec 22, 2004 | 11:16 PM
Solscud007's Avatar
Default Re: Newbie B16 motor owner (DC2-99)
really itr piston heads will lower CR? why is that? arent they domed compared to regular B16 pistons
Old Dec 23, 2004 | 05:49 AM
D-Rob's Avatar
Yes, but I believe it has to do with wrist-pin placement...?
If you want OEM higher compression pistons, go with Civic Type R PCT pistons.
Although, I think you need to machine off a millimeter off both sides of the rod... I don't know. There's a sticky thread at the top that explains all about the PCT's.
- Derek
Old Dec 23, 2004 | 07:43 AM
AlLMoToRvOtEr's Avatar
Default Re: Newbie B16 motor owner (drobinson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drobinson &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but I believe it has to do with wrist-pin placement...?
- Derek</TD></TR></TABLE>
Very good, yes ITR's have a different wrist pin placement because of the 1.8 stroke is longer so yes they will be very close to the stock pistons as far as compression. Go with CTR much better. B16 with CTR pistons and a ITR head as long as it is tuned well will push between 170 and prolly about 185 whp.
Old Dec 27, 2004 | 03:19 PM
Solscud007's Avatar
Default Re: Newbie B16 motor owner (AlLMoToRvOtEr)
thanks guys. Hmm maybe i should trade those ITR pistons for CTR then haha.
oh what does PCT mean?
Old Dec 27, 2004 | 03:28 PM
kaptr1d's Avatar
pct is the piston code for ctr pistons.
pct = ctr
crxowner
Jul 26, 2005 05:57 PM
civic-si-2000
Jun 2, 2005 07:57 AM
rcurry14
10
Aug 6, 2004 08:36 PM
VtecDA9
Jun 2, 2003 07:35 AM
SIReg9
Nov 6, 2002 10:34 AM
