does a h22 manifold fit a f22 head ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj »</TD></TR><TR><TD CLASS="quote">NO.</TD></TR></TABLE> Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">your backwords...
f22 o oo o
h22 o o o o</TD></TR></TABLE>
Incorrect to a certain degree.
f22a are 0 0 0 0 too.
H23's are 0 0 0 0 as well.
f22b's/23a's are 0 00 0.
H22's are ? ? ? ?.
I think they are 0 0 0 0 as well but are different enough to not work with the H23 and f22a 0 0 0 0.
f22 o oo o
H22's are ? ? ? ?.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK_DEL_SOL »</TD></TR><TR><TD CLASS="quote">ok if i have a h23a turbo manifold will it fit on a f22b</TD></TR></TABLE>
NO.
NO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnightaccord »</TD></TR><TR><TD CLASS="quote">h23 manifold will fit on a f22b. </TD></TR></TABLE>
How so?
Id like to know.
How so?
Id like to know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92F22 »</TD></TR><TR><TD CLASS="quote">You all are all confusing me.
(O O O O)
This is my JDM F22 DOHC uses same parts as the H23
thats becuase H23 is a bored or stroked (i forget) DOHC f22
(O O O O)This is my JDM F22 DOHC uses same parts as the H23
</TD></TR></TABLE>thats becuase H23 is a bored or stroked (i forget) DOHC f22
I was under the impression that the f22b DOHC had the same exhaust manifold pattern as the f22a engines. There are several guys on cb7tuner that run DSM setups on their f22b DOHC engines.
Holy **** how is this so hard... (the "x" stands for some random number)
F18A, F20A (sohc/dohc), F22B, H23Ax, F22Ax - same
F22Bx,F23Ax - same
H22A, H22Ax, F20B, H23A (vtec) - same
So yes the H23 manifold will fit your dohc f22b perfectly fine.
EDIT:
Also h23/f22's all have the same stroke, h23 has a 87mm bore where f22s use 85.
f23s have a bigger stroke and 86mm sleeves
F22Bx,F23Ax - same
EDIT:
THis is not the first time that I've seen this come up, in my limited stay so far here on H-T.
Is it my understanding that the DSM 4G63T parts are direct bolt-ons to the Honda F22B?
If so, sweet... I know a LOT of DSM guys whom I can pillage parts from :D
