97 ls motor swap into 95 ex
Old Dec 22, 2004 | 11:17 AM
projecthybrid04's Avatar
Default 97 ls motor swap into 95 ex
can i use the stock ls wireharness w/out moddifiying to fit in my car? if not what wire harness would i have to use, i want to stay obd1, so do i get a obd1 pr4 or a obd1 p75 ecu?
Old Dec 22, 2004 | 12:01 PM
smart monkey's Avatar
Default Re: 97 ls motor swap into 95 ex (projecthybrid04)
if you have the 97 ls harness and dist you can use it. if not you can use the ex one and either do a plug change if you have the ls OBD2 dist or get a OBD1 ls dist. also as for ecu's you can use a 92-93 PR4 or a 94-95 p75.
Old Dec 22, 2004 | 03:45 PM
Default Re: 97 ls motor swap into 95 ex (smart monkey)
o thanks alot, your info helped greatly
Melbz
Oct 5, 2014 05:16 PM
nj0127
Apr 29, 2013 03:23 PM
topshotta
Mar 21, 2010 10:58 AM
eggsi619
May 4, 2009 03:12 PM
Patron
Jan 2, 2002 02:43 PM
