Had a small last night....I think I bent my tie-rod.....
Basically what happened is that I was driving home from work with the roads still being pretty slippery from the last snowfall that happened a few days ago. I was going about 15mph or maybe a little faster and had to make a right sharp turn. Instead of turning I slid my car into my curb. Afterwards when I checked to see what happened my car was a little messed up. My left front tire was toed in so my car kept pulling to the right until I got home. Luckily enough I wasnt that far away so I didnt have to call a tow truck or anything. I think I may have bent my left tie-rod. After jacking up my car when I got home I checked it out again and there didnt appear to be any visible damage or atleast anything broken. I think I got lucky by sliding into the curb as opposed to going straight over it. How much do you think a new tie rod would cost me and would it take long to install a new one? Im just trying to get a rough estimate so I know what to expect before I bring it into the dealership......Thanks....
part will cost you about $25 - $50. I did mine this weekend in less than an hour. it's super easy
you'll need an alignment afterwards though.
I just went to the dealership and found out it was actually the lower control arm being bent. Its gona cost me roughly $100 to diagnose if there is anything else that is bent and then the cost for a new one im guessing and then the labor for that. Damn I never knew hitting a curb at less than 20 miles an hour can cost so much......
Yeah, I did the same thing last winter. I just went and got an alignment though. It's been fine ever since. Just don't make the mistake I made and wait a couple months. You will ruin your tires. Good Luck.
yea, that's like one of the worst things. my friend has an old 92' taurus SHO and he hit a curb and bent his tie rod and his subframe. the repair was to cost nearly $2000, which was just about or more than the value of his car. so now he just drives it around all crooked and illegal. hitting curbs suck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out »</TD></TR><TR><TD CLASS="quote">i think u jizz put ur car out of align...re alighn it</TD></TR></TABLE>
It actually didnt turn out to be my tie-rod it was actually my lower front control arm which really sucks. I need more than just a alignment..The dealership wants $800 to fix it so I said screw it and im getting the parts myself and have a friend help me out....
a front lca is very easy to change out, like 3 bolts out back, then take the shock off, and then pop the knuckle off the botom and unbolt it from the crossmember, i can do it in 45 mins with power tools, i just came inside from changing my outer tie rods and it took me about 10 minutes total... i guess im kinda fast but front ends are no big deal to me, sucks tho, igotta go change my inner tie rod too, damn it
I did a similar thing in the '80's to my '76 Capri. Fooling around in snow and hit a curb pretty hard. Found out later (10,000 miles later) that I had bent the sway bar. That car had a "true" MacPherson strut front suspension and with those the sway bar is an intregal part of the front suspension. I was so pissed off and cheap I refused to get it fixed and drove it like that for a l o n g time. Both front wheels were pointing in different directions with neither one pointing straight. I finally got sick and tired of my steering column vibrating my eye teeth out every time I put on the brakes so I broke down and got it fixed. They told be the sway bar was bent. I don't remember how much it cost to get fixed, but I had to get a new set of tires too since I wore out an expensive set of tires by being a hard head. I think the total for the suspension and tire fix was $600. This was a lot of money in 1982 and I was only making maybe $25000 a yeat (if that).
2mansi
Oct 7, 2006 05:13 PM
madhatter07
11
Jan 31, 2006 11:17 AM
jarvis199
54
May 5, 2005 02:15 PM
