Which JDM cable LSD trannies compatible with my 91 LS clutch and 90-93 axles?
Old Dec 22, 2004 | 09:34 AM
BlueShadow's Avatar
Default Which JDM cable LSD trannies compatible with my 91 LS clutch and 90-93 axles?
Hi guys,
It's time for me to upgrade my tranny, and I was thinking about getting a cable LSD tranny. However I just need to check and see if I would run into any problems with the clutch I'm using now. Right now I have a 91 LS clutch and PP on my B18C, because I'm running a 91 LS tranny which was supposed to be temporary.
So can I run a J1 LSD without having to change out my 91 LS tranny and 90-93 axles?
TIA
Old Dec 22, 2004 | 09:53 AM
EL Vap133's Avatar
Default Re: Which JDM cable LSD trannies compatible with my 91 LS clutch and 90-93 axles? (BlueShadow)
I didn't know the J1 was an LSD tranny. You could however use the Y1 LSD tranny.
Old Dec 22, 2004 | 10:02 AM
BlueShadow's Avatar
Default Re: Which JDM cable LSD trannies compatible with my 91 LS clutch and 90-93 axles? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know the J1 was an LSD tranny. You could however use the Y1 LSD tranny. </TD></TR></TABLE>
Opps, yah that's the one I meant...the one that had optional LSD. I just needed to know if I could use my 90-93 Teg LS axles with it, or if I needed something like JDM SiR axles or something. And I also needed to know if my 91 LS clutch would also work with the Y1 LSD tranny.
TIA
Old Dec 22, 2004 | 10:19 AM
EL Vap133's Avatar
I used 90-93 teg axles and my 91 Teg clutch when I had my Y1 LSD tranny.
Old Dec 22, 2004 | 10:23 AM
Solscud007's Avatar
where is a good place to get the y1 LSD tranny? besides the for sale section? I tried hmotorsonline but they wont separate the tranny. and Password wants a ridiculous $1100 bucks for a tranny that should be like 500
Old Dec 22, 2004 | 10:29 AM
BlueShadow's Avatar
Default Re: Which JDM cable LSD trannies compatible with my 91 LS clutch and 90-93 axles? (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">where is a good place to get the y1 LSD tranny? besides the for sale section? I tried hmotorsonline but they wont separate the tranny. and Password wants a ridiculous $1100 bucks for a tranny that should be like 500</TD></TR></TABLE>
Thanks for the info EL VAP
Solscud007,
Check out http://www.jdmshit.com and look under "ENGINE COMPONENTS". They have a listing for JDM trannies starting at $395. You can also contact Newman on H-T who runs jdmshit.
Old Dec 22, 2004 | 10:47 AM
Solscud007's Avatar
yeah they said they didnt have any and I need one to start driving my new car
Old Jan 4, 2005 | 02:48 PM
oldskool teggy's Avatar
that y1 lsd tranny is worth more then $500
Old Jan 4, 2005 | 04:10 PM
EL Vap133's Avatar
That was one of the reasons I went with the USDM ITR hydro tranny. Also because cable trannies are becoming more and more scarce.
japanstar_ef9
Feb 9, 2008 02:59 PM
votoms888
May 14, 2007 05:15 PM
dragaholic
12
Jul 20, 2006 08:07 PM
LSV_REX
Jul 4, 2005 05:47 PM
