What is valve lash?
Old Dec 22, 2004 | 06:33 AM
one slow coupe's Avatar
Default What is valve lash?
I asked this question in the all motor section and i got flammed. so ill ask it here..what is valve lash and what does it have to do with installing cams...i have an idea somethin about how much "play" is in the cam or retainer or something? how is it adjusted...
Old Dec 22, 2004 | 06:56 AM
hott95eg's Avatar
Default Re: What is valve lash? (Honda_b16a2)
valve lash is the clearance between the valve stem and rocker arm, the is a locknut and screw used to adjust valve lash on the rocker arm
Old Dec 22, 2004 | 10:49 AM
Default Re: What is valve lash? (hott95eg)
i posted about installing CTR cams and i was told to set the lash at 7 and 7 so does that mean set the intake clearance to 7 and the exahsut clearance to 7, what does 7 mean btw?
Old Dec 22, 2004 | 03:26 PM
sleeping GIANT's Avatar
.007 mm , get yourself a set of feeler gauges from sears,parts store, and follow the helms,chilton,or haines manual for a 2000 civic si to set valve lash. its very simple , just time consuming and not something you want to get in a hurry on.
- set piston #1 to top dead center
- start w/ the intake valves then do the exaust
- set piston #3 to top dead center
- then #4
- then #2
read the book its a peice of cake! if you need complete directions im me.
Old Dec 22, 2004 | 07:01 PM
Lord Helmet's Avatar
Default Re: What is valve lash? (sleeping GIANT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeping GIANT &raquo;</TD></TR><TR><TD CLASS="quote">.007 mm , get yourself a set of feeler gauges from sears,parts store, and follow the helms,chilton,or haines manual for a 2000 civic si to set valve lash. its very simple , just time consuming and not something you want to get in a hurry on.
- then #4
- then #2
read the book its a peice of cake! if you need complete directions im me.</TD></TR></TABLE>
nicely put
Old Dec 22, 2004 | 07:13 PM
Combustion Contraption's Avatar
You also need to buy/make a special tool to do the DOHC VTEC engines.
Old Dec 22, 2004 | 07:16 PM
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">You also need to buy/make a special tool to do the DOHC VTEC engines.</TD></TR></TABLE>
snap-on sells it, pretty cheap too. forgot the link though
Old Dec 22, 2004 | 07:38 PM
EKhatch's Avatar
Default Re: What is valve lash? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
nicely put </TD></TR></TABLE>
Well not really.
.007mm are you kidding me?
How about .007in.
Old Dec 22, 2004 | 08:24 PM
hott95eg's Avatar
Default Re: What is valve lash? (EKhatch)
you may want to bump the exaust side up to .008 or .009 .HEAT KILLS
Old Dec 23, 2004 | 01:14 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95eg &raquo;</TD></TR><TR><TD CLASS="quote">you may want to bump the exaust side up to .008 or .009 .HEAT KILLS</TD></TR></TABLE>
Old Dec 23, 2004 | 03:25 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95eg &raquo;</TD></TR><TR><TD CLASS="quote">exaust side up to .008 or .009 </TD></TR></TABLE>
Better to be too loose than too tight.
But thats what she said...
Old Dec 24, 2004 | 05:21 AM
EKhatch's Avatar
Default Re: What is valve lash? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, I little loose and you get a little more noise from the valvetrain (arguably a ever so slight power loss).
A little too tight and you could be in a world of hurt.
Ryan15
Oct 5, 2006 07:00 AM
Dat_One_Si
Sep 23, 2006 07:43 PM
mrfi2
Sep 12, 2004 05:30 PM
SpoonFed
May 9, 2002 08:09 PM
