Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what is your swaybar set up? rear only, front and rear, none, front only?
Old Dec 22, 2004 | 01:02 AM
volkdlr's Avatar
Default what is your swaybar set up? rear only, front and rear, none, front only?
I know some people run a rear swaybar only and not the front just curious what you all have?
Old Dec 22, 2004 | 01:52 AM
jc836's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (volkdlr)
With the spring rates I am running currently on the CRX Si (400F/500R) we have an ADDCO rear bar and the stock front one. The car rotates quite well. I have Camber adjusted to the limits of stock rather than the typical track settings that are over 2 degrees.
Old Dec 22, 2004 | 01:53 AM
travis's Avatar
Here's a CRX specific thread, but it has some good info:
https://honda-tech.com/zerothread?id=794339
I'm running a ST rear bar and no front. (450/600, 2*/2.5* camber, 1/8" out front toe)
Old Dec 22, 2004 | 03:58 AM
DSPDA3's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (travis)
Addco rear bar (3/4") and stock front bar on an '89 Integra.
Old Dec 22, 2004 | 07:00 AM
slammed_93_hatch's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (DSPDA3)
Comptech rear sway bar setup, none up front. currently looking for new spring rates
wheel as of now the car is currently just taking up space but eventually it will be a race car
Modified by slammed_93_hatch at 5:35 PM 12/22/2004
Old Dec 22, 2004 | 07:02 AM
johng's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">Comptech rear sway bar setup, none up front. </TD></TR></TABLE>
what he said.
race car
Modified by johng at 1:52 PM 12/22/2004
Old Dec 22, 2004 | 09:38 AM
Marauder's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (johng)
Integra: Front: Suspension Techniques 1", rear: SpeedTech tie bar/7/8" sway
Civic: Eibach anti-roll kit
Old Dec 22, 2004 | 10:39 AM
nonsense's Avatar
I have none at all, but I'm looking to get an ITR rear with a Beaks kit pretty soon.
p0pe's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (Marauder)
01 S2000 setup for autocross in A-Stock
front - 1.25" solid bar (saner)
rear - stock
Modified by p0pe at 5:16 PM 12/22/2004
Old Dec 22, 2004 | 10:40 AM
stormy's Avatar
none
I am still working on the rest of my alignment, height and spring settings to throw those into the mix as well
right now my car is not as low as I would perfer it so I am waiting on shorter eibachs
Once I get those and set the height then I will set the alignment which will be very close to dead on factory specs
The wheels sized for bakes and then decide tire widths which will be max 205's
Then alot of time stiffening up the car through caging further supension reinforcement ect
Then lots of track time
then watch outside video to the see the results
then maybe sway's
Old Dec 22, 2004 | 10:42 AM
SPiFF's Avatar
H3/ITS GSR:
Stock front bar, Mugen 22mm rear bar.
Old Dec 22, 2004 | 10:44 AM
bad-monkey's Avatar
A/X (STX); HPDE prelude
450/550
progress 27mm rear, no front.
bumping spring rates up to 550/700 eventually.
rotates well, almost to the point of being too loose for me, body roll isn't much of an issue atm, but plenty of things are changing so i'm not getting too attached.
Modified by bad-monkey at 10:24 PM 12/22/2004
Old Dec 22, 2004 | 12:35 PM
Tyson's Avatar
you know, i think it would be more useful if everyone who has added some comment to this thread stating their "setup" would go back and ADD what you actually DO with your car (street, autox, HPDE, road RACE).
Old Dec 22, 2004 | 12:56 PM
solo-x's Avatar
Default Re: what is your swaybar set up? rear only, front and rear, none, front only? (Tyson)
autox on street tires, occasional HPDE
front and rear swaybars, both big.
custom valved koni's.
really fricken stiff springs for an autocross car, stiff ones on the wrong end.
nate
Old Dec 22, 2004 | 06:13 PM
95Sol's Avatar
i have front and rear suspension techniques sway bars on my daily driver/auto-x car.
B18C5-EH2
Feb 6, 2018 01:50 PM
B18C5-EH2
Suspension & Brakes
Feb 5, 2018 01:38 PM
Motionek55
Suspension & Brakes
Sep 4, 2012 03:53 PM
dvp
60
Sep 30, 2005 04:35 PM
deviant1
10
Aug 24, 2004 05:43 AM
