Need advice on d16y8?
Old Dec 21, 2004 | 07:05 PM
fozzy_bear's Avatar
Default Need advice on d16y8?
I recently blew a rod in my 98 civic ex. Is it better to swap it out, or rebuild? If I swap it, what will fit in its' place? can I only use a d16y8, or something else? I'm obviously confused........ Any help is appritiated!
Old Dec 22, 2004 | 04:11 AM
civic-4-ges's Avatar
Default Re: Need advice on d16y8? (fozzy_bear)
You can usually get d16y8 shortblocks pretty cheap. I would just swap it out
Old Dec 22, 2004 | 10:43 AM
tgreaves's Avatar
If you snapped a rod in your motor more than likely the block is toast and at the very least the cylinder is messed up completly.. I would look for a new short block..
Old Dec 22, 2004 | 01:56 PM
vtekstorm's Avatar
Default Re: Need advice on d16y8? (tgreaves)
i did that on my 99 ex i blew my motor i swapped it out
Old Dec 23, 2004 | 04:31 AM
fozzy_bear's Avatar
Default Re: Need advice on d16y8? (vtekstorm)
Can I only swap with d16y8, or will another engine fit?
Old Dec 23, 2004 | 04:39 AM
Y7 will fit, so will Y5 (same obd generation as the y8)
You could swap in a z6 or damn near any other D16 block too, but there will be slight issues with sensors on the older blocks
Old Dec 23, 2004 | 05:53 AM
tgreaves's Avatar
I would look for a y8, y7, z6 in that order..
Old Dec 23, 2004 | 06:22 AM
fozzy_bear's Avatar
Havin' trouble findn' a y8 at the local junkyards. Anywhere better to look?
Old Dec 23, 2004 | 06:26 AM
tgreaves's Avatar
Here on HT or on ebay..
D-SERIES.ORG
liljukmoves
19
Aug 12, 2020 02:58 AM
2210a
Jun 9, 2016 07:03 PM
khmaiabz
Oct 4, 2008 02:12 PM
civic4door95
Apr 11, 2004 08:33 PM
