Drop in Oild Pressure Saga
Thanks to those of you that gave me your suggestions/recommendations while I was trying to figure out why my low oil pressure light was coming on all of a sudden. I followed several of yours advice and dropped the oil pan. You were right. Really easy! Fortunately no metallic shavings! The pick up screen was about 80% clogged with carbon type build-up. The only part of the screen I could see was right below the slit in the pickup. Pretty much the rest of it had the buildup on it. The rest of the engine was really clean. Just the pick up was clogged. Cleaned it up real good and everything seems to be fine now. Thanks again guys!!!!!
