CLUTCH PROBLEM
ok well i just got my clutch master cycl intalled.. a new one (aftermarket) i have a new clutch stage 2 that was installed in june .. i have a h22 in hte car. but when i changed my master clutch cyc.. after about a week at some times i couldnt put the car into gear. after leaving the car turned off for a bit the car would then be able to be put into gear. i took it bakc tot he shop i got it installed at and they say that the clutch is causing a bit a pressure on the the line.. so he changed the pressure of the line.. he say thats well try this and then if it doesnt work.. change the mater clutch cyc and the slave... would that be the best thing to do?
I had the same problem and had to swap both out. They did that after the master cylinder was replaced and the was taken into the shop 3 or 4 times afterwards because I was having problems getting it into gear.
phatsindabuildin
Mar 25, 2008 06:57 PM
sniperslayer
Nov 6, 2005 10:00 PM
