How long before you wear out your piston rings from "squeezing"?
Old Jan 5, 2002 | 11:03 AM
Duck Sauce's Avatar
Default How long before you wear out your piston rings from "squeezing"?
Let's say you spray a few times a month at the races. Your bottom end is stock but in good condition. How long before your piston rings start to deteriorate from using Nitrous? TIA.
Old Jan 5, 2002 | 11:32 AM
non-VTEC's Avatar
Default Re: How long before you wear out your piston rings from "squeezing"? (www.s4-mtm.com)
what pistons and rings are you using?
honda rings...........they burn up pretty quick even without juice.........
JE sells high tension rings what really hold up well!
Old Jan 5, 2002 | 01:07 PM
Duck Sauce's Avatar
Default Re: How long before you wear out your piston rings from "squeezing"? (non-VTEC)
Yeah, stock pistons and rings for now. Ever heard of Total Seal rings?
Old Jan 5, 2002 | 02:01 PM
non-VTEC's Avatar
total seal rings really suck........ask anyone who tried them.......do a search i think it's been coverd before.
honda rings are accualy quite good. but if they have alot of miles on them they wear out especially with alot of high rpm. but they are not meant for high rpm+heat+stress like NOS will give them.
Old Jan 6, 2002 | 12:32 AM
Mista Bone's Avatar
D Tranny Guru
20+ bottles and still going!!!!
About the Total Seal rings. I'll bet the house NO ONE ever bothered to contact the manufacturer to see what hone pattern/finish was needed.
Just 20 year old info from a V8 dude playing with 1/2 as many cylinders, 1/4 the displacement.
quik1
Jun 22, 2004 08:14 AM
SanoJDm
Mar 20, 2003 12:54 PM
non-VTEC
Sep 21, 2002 02:23 AM
samiam
Jan 28, 2002 04:43 AM
