crx with 94-95 gsr swap obd1. Parts list? How to?
I know ive seen this post before ive been searching forever usually i find it on google but i cant. Im looking for kinda like a swap guide or parts list type write up. Like radiator hoses ect...anyone know where that post is or any other one?
actually used both hoses from 90-93 integra.. what mounts are you using? how did you wire up your OBD-I stuff? are you still going to use the GSR intake mani?
well i ahevtn done the swap yet im waiting on my motor. Yea im sticking with the stock mani for now cause im going to BAR it. the mounts are like old school hasports. Blown90hatch is gonna hook me up with the ecu plug in harness and he's going to wire up my harness and re plug it for me to make it as close to plug and play that he can
not too much else you have to modify.. the intake mani fits really tight, you probably won't be able to pull it off or put it on without pulling the motor out
wire up an obd-I GSR distributor or any from a B16a, non-vtec dist. don't work right (they don't bolt up either, but you can ghetto rig them)
you're gonna need a throttle cable from a 94+ GSR
can't think of what else at the moment, good luck though
Well i know when i did my LS swap i had to get those 2 round things that go on the firewall that 2 vaccum lines hook to. What about with the gsr? does it have 1,2, 3 ect? i need to know any little stuff cause im going to get the whole front clip so i need to pull off anything i need.
I know there has to be a rite up on this.
youll need lots of stuff
and there lots of variable...what tranny...are you converting to obd1, what radiator.
search under archive
https://honda-tech.com/zerothread?id=996961
Heater hoses were kinda wierd, someone said CRX Si hoses work.
If you are using the stock intake manifold you may have to go with a CAI or MiniRam. I couldn't get stock black hoses to mount to the airbox nicely.
90-93 axles or 94+ Integra axles as long as you use the matching int. shaft.
If you use your CRX speedo drive you'll need a longer speedo cable. If you use an integra speedo drive it is taller and might work ok or you could convert to electric.
BLK99VTECR
11
Jul 22, 2003 10:20 PM
