WHat fuel filter goes in a 91 CRX w/b16a??? I thought...
Old Dec 20, 2004 | 01:09 PM
Nevaeh's Avatar
Default WHat fuel filter goes in a 91 CRX w/b16a??? I thought...
Wouldnt using a fuel filter from a 2000 civic Si be better than the stock filter for the Si CRX? I have a 91 crx Si with a b16a in it.
And If I want to buy a valve cover gasket set, what do I buy, seeing as how I have a jdm engine? Is it the same as a b16a2? Need to know, and thanks a whole bunch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 20, 2004 | 01:15 PM
WhiteDSM520's Avatar
Default Re: WHat fuel filter goes in a 91 CRX w/b16a??? I thought... (Nevaeh)
Just use the stock one. It's a sure fit.
As far as ordering/buying parts for the engine itself, when i go to http://www.hondaautomotiveparts.com, I select 94 DEL SOL VTEC. Everything should fit.
Nevaeh's Avatar
trying for a quick response. bump.
Old Dec 20, 2004 | 01:20 PM
BlueShadow's Avatar
You'll wanna use the fuel filter from the stock CRX/Civic instead of the 2000 Civic Si one. If you look at the Civic CRX filter, the inlet and outlets are both at the top of the filter, while the 00 Si has the inlet at the bottom and the outlet at the top. So some custom work will need to be done to get the 00 Si filter to fit in your car.
As for the valve cover gasket, I'm almost certain you can use any B series VTEC VC gasket from 94+ GSR or ITR, or from the Del Sol DOHC VTEC or the 99-00 Civic Si. But just to be on the safe side you can order the VC gasket as well as all other parts from the Del Sol VTEC.
Old Dec 20, 2004 | 01:37 PM
Nevaeh's Avatar
Default Re: WHat fuel filter goes in a 91 CRX w/b16a??? I thought... (BlueShadow)
thanks guys. anyone using a K&N oil filter? and what is ht ereference number if you happen to know? I know thats a funny question.
Old Dec 20, 2004 | 01:45 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nevaeh &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys. anyone using a K&N oil filter? and what is ht ereference number if you happen to know? I know thats a funny question.</TD></TR></TABLE>
K&N oil filter HP 1004 should work for you
http://www.knfilterchargers.co...-1004
Old Dec 20, 2004 | 08:54 PM
Nevaeh's Avatar
thanks, everyone.
91crxb18
Jan 16, 2007 07:19 AM
jchrm80
Aug 24, 2006 06:26 PM
paulseaside
Jun 4, 2006 08:36 PM
typesguy
Nov 18, 2003 06:11 PM
unabonger
Mar 2, 2003 11:34 PM
