si vs. integra rear disc brakes
Old Dec 20, 2004 | 12:36 PM
sightless's Avatar
Default si vs. integra rear disc brakes
what are the differences... im putting them on my EK which ones better?
also is rear disc helpful or just for looks...
and is $150 for a rear disc conversion a good price?
Should I get crossdrilled/slotted rotors too? will that help me
and is PBR vs. Autozone Semi Meatallics... does it really matter?
Thanks for answering
Old Dec 20, 2004 | 02:02 PM
sightless's Avatar
Default Re: si vs. integra rear disc brakes (sightless)
I need to know
lol
hehe
Old Dec 20, 2004 | 05:41 PM
86si's Avatar
thay are the same
Old Dec 20, 2004 | 05:55 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">thay are the same</TD></TR></TABLE>
All rear discs and trailing arms are the same. The exception is the DA trailing arm. DA trailing arms have longer compensator arms and a bigger trailing arm bushing, other than that they're the same as the others.
I think it looks better and will run cooler since you have airflow across the rotor. The only reason i converted was because i didn't know how to change drum brakes.
What's included for $150?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sightless &raquo;</TD></TR><TR><TD CLASS="quote">
Should I get crossdrilled/slotted rotors too? will that help me</TD></TR></TABLE>
I think those are for looks. I use oem rotors.
Old Dec 20, 2004 | 10:32 PM
sightless's Avatar
everything to convert to
Old Dec 20, 2004 | 10:53 PM
Katman's Avatar
$150 is about right for rear disc conversion.
they do work better than drum brakes along with looking better
staying with a stock rotor or going cross-drilled is up to you. Personally, I'd either run a stock rotor or slotted, crossed drilled are known for warping faster (at least on front rotors).
Old Dec 20, 2004 | 11:34 PM
sightless's Avatar
thanks guys!
Old Dec 27, 2004 | 06:47 PM
eK9aT10pSi's Avatar
im curious, i know with the eg's, the teg rear discs bolt up just fine. i have a 99ex and my drums are about dead. instead of doing the rear shoes, i figured that the discs would be easier and more or less the same cost in the end. for the 96-00 ex, is the only option to use the 99-00 si rear trailing arms? thanks
Old Dec 27, 2004 | 08:01 PM
TIRENECK's Avatar
Default Re: si vs. integra rear disc brakes (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">im curious, i know with the eg's, the teg rear discs bolt up just fine. i have a 99ex and my drums are about dead. instead of doing the rear shoes, i figured that the discs would be easier and more or less the same cost in the end. for the 96-00 ex, is the only option to use the 99-00 si rear trailing arms? thanks</TD></TR></TABLE>
U can use any DC year disc brakes.
iloveb16
Northwest (Sales)
Jul 6, 2009 05:20 PM
asianflava
Dec 8, 2008 11:14 AM
Unsivil_audio
Jul 6, 2008 01:24 PM
wdskuk
11
Jul 6, 2004 11:08 AM
DOHC-DX
11
Sep 18, 2002 06:47 AM
