What else am I forgetting? (radiator fan problem)
based on that j00 should get a new swtich......or j00r water temp never goes above 93deg C....which doesn't seem likely unless you have a very big radiator and it's cold out and you don't wait long enough.
reading owns me...
if the fan turns on when the switch is shorted then the rest of the system works, which should narrow it down to the switch itself, no?
do you have an aftermarket radiator?
test the socket where the relay plugs in, in the engine compartment fuse/relay panel. I had the same problem and it turned out to be that. To fix it I just ran the fan to a manual switch, and have not had a problem since,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack »</TD></TR><TR><TD CLASS="quote">Where does your factory temp gauge sit at...approximately?</TD></TR></TABLE>
305S0L
May 13, 2008 12:43 PM
Joey.
Apr 20, 2006 03:41 PM
toeknee360*
Sep 13, 2005 11:06 AM
