Replacement PCV Valve
If you are replacing the PCV valve on a 97 accord 4cyl is it best to go OEM or would a replacement from Advance auto parts be just as good? How often do you think replacement is required? Thanks!
Go to some autozone/kragen does the same job but I'd go OEM on like vital parts You could go OEM I think its about 5 dollars for OEM and 2 for some autoshop
Manchester Honda wants 19.95 for OEM. Seems excessive price to me. Anything special about a Honda PCV over others? Sounds like I will stop at autozone on the way home tonight.
I myself like to stick with OEM Honda.
$20 sounds a bit high, I would think the PCV would run about $15 from the dealer. $2 from AutoZone (or the like) sounds a bit low, I think they cost a little more than that.
pityocamptes
29
Feb 8, 2014 06:44 AM
brianmcivics
Nov 29, 2007 05:48 PM
