whats the difference between a f22a1 and a f22b engine ?
Old Dec 20, 2004 | 08:54 AM
BLACK_DEL_SOL's Avatar
Default whats the difference between a f22a1 and a f22b engine ?
i have a f22a1 in my 94 lx and i got a f22b head from a 95 ex , can i do a head swap and what parts do i need to do it ? and is the f22b head vtec some friends told me yes and some said only the f23 is vtec is that true ?
Old Dec 20, 2004 | 09:00 AM
SpeedFreak77's Avatar
Default Re: whats the difference between a f22a1 and a f22b engine ? (BLACK_DEL_SOL)
It is the V-tec, not too sure on the parts you would need I will let someone else tackle that.
Old Dec 20, 2004 | 09:04 AM
Default Re: whats the difference between a f22a1 and a f22b engine ? (SpeedFreak77)
but the vave cover didnt say vtec on it ? but i was a white or pearl color instead of the black one ?
Old Dec 20, 2004 | 09:45 AM
TouringAccord's Avatar
H-T Order of Merit
The 94 EX was the only year that the valve cover was black if I remember correctly. If you did infact get a head from a 95 EX then it should be like a light grey color if stock and should have VTEC writen across the valve cover. Also the spark plug tubes should be on the front of the valve cover (nearest the exhaust ports on the head). Are you sure you got it from a 95 EX with a F22B1 SOHC VTEC?
Oh, also. I just read that again and you said you have a F22A1 in your 94 LX? If you do have a 94 LX then you should have a F22B2 SOHC Non-VTEC.
As for a parts list, I'm not real sure. I know it's been done and a write-up was done as well. Search the archives for it. It was done on a 90-93 Accord with a 94-97 VTEC head. The part I can remember right now is the timing belt, can't remember what else needed to be done.
Old Dec 20, 2004 | 10:19 AM
Default Re: whats the difference between a f22a1 and a f22b engine ? (TouringAccord)
OK mine is a f22a1 and the valve cover is light grey or silver but it doesn't say vtec ?
Old Dec 20, 2004 | 10:38 AM
H-T Order of Merit
ok, I'm lost. How do you have a F22A1 in your 94 LX? Did you or someone swap it?
Old Dec 20, 2004 | 11:10 AM
91wagon's Avatar
Yea, the f22a's came in 4th gen accord, correct? If you do have a f22a in a 5th gen, that is strange.
Old Dec 20, 2004 | 11:51 AM
Default Re: whats the difference between a f22a1 and a f22b engine ? (91wagon)
SORRY its a f22b
Old Dec 20, 2004 | 01:32 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK_DEL_SOL &raquo;</TD></TR><TR><TD CLASS="quote">SORRY its a f22b</TD></TR></TABLE>
almost, it's a F22B2.
Search, it's been done before. You should be able to find the info you need.
Old Dec 20, 2004 | 02:32 PM
Legendaryyaj's Avatar
Why stay SOHC when you can go DOHC.
https://honda-tech.com/zerothread?id=776837
iblandford
18
Jul 10, 2006 11:13 PM
_HANS
Northeast (Sales)
May 14, 2006 08:31 PM
DieMaster
Dec 12, 2005 08:53 AM
Slammed95Cord
Mar 14, 2004 08:47 AM
TinLizzy
Oct 19, 2003 02:17 PM
