Gen 3 Integra GSR ABS Removal
So after a bit of research I am ready to jump in to remove my terrible ABS from my ITS GSR. Here is the list of parts and directions I think need to happen. If anyone has done this please chime in as I have not done it yet, but getting ready to pull the trigger!
The way I understand the rule book, this approach is a legal approach in IT.
Parts Needed from a 1994/1995 Integra 3 DR RS
- Front Left metal brake line from flex lines to prop valve
- Front Right metal brake line from flex lines to prop valve
- Both lines that run from the prop valve to the master cylinder
- Prop Valve
Tools:
- Tubing Bender and Flare Tool
- Patience
Facts:
- The GSR master cylinder is different than the RS. The RS has both lines feed from the drivers side of the MC, where the GSR has a line on both sides.
- The rear brake lines do not need modification.
- The front two lines to the flex lines are self explainatory
Where it Gets Messy:
- The two lines out of the valve and to the MC will need to be rebent to fit the GSR MC. This may also require different size fittings, but one could easily enough re-use the ones off the lines you just removed.
Am I missing anything?
Is it good practice to buy all the goods new from Acura or is it ok to buy at the junkyard? Any opinons?
- Prop Valve
Tools:
- Patience
Facts:
This sounds good, i want 2 do the same thing 2 my Civic...accept all my lines are fine and i just happen to have all integra harnesses in my car, including dash and stuff. I have a mess of wires right behind the passenger headlight, including AC harnesses/ABS/SRS(i think), but the head light, and corner light go into that mess also. Anyone rip out the wiring b4 and still have everything work right? Please give me some info, i can take pictures to describe the mess better if needed.
All the wires with orange plugs on them are for ABS equipment.
All wires in yellow are SRS Equipment
A/C is not that cut and dry!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">why not just pull the fuse??</TD></TR></TABLE>
or unplug it in at the ABS module.
I belive the bore on the MC is diffrent too..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECAcuraGSR »</TD></TR><TR><TD CLASS="quote">Parts Needed from a 1994/1995 Integra 3 DR RS
- Prop Valve</TD></TR></TABLE>
That is what I came up with as well. I have the parts, but don't plan to do this for a while. I am already changing too much on the car over the winter in one shot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Facts:
- The GSR master cylinder is different than the RS. The RS has both lines feed from the drivers side of the MC, where the GSR has a line on both sides.</TD></TR></TABLE>
Hmm .. didn't realize that. I am glad you are doing this first.
You could do this, but to my understanding when you pull the fuse the ABS Front/Rear bias is not as good as it is on the RS models that is non-ABS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ »</TD></TR><TR><TD CLASS="quote">
See above!
Third - You want to get rid of every pound you can on the front of the car and the ABS is suppose to be worth almost 40-50 lbs!
See above!
See above!
Third - You want to get rid of every pound you can on the front of the car and the ABS is suppose to be worth almost 40-50 lbs!</TD></TR></TABLE>
Exactly, so how do i remove the wire harnesses for abs, ac, and srs...so ugly
See above!
I would just go to http://www.evansautomotive.net and get in touch with Jeff Evans and tell him to pull the lines you need from a non ABS car and ship them to you. Evans Automotive is a Honda salvage yard and they have been very helpful to me. They have over 2000 salvage cars on their lot. Just tell them Lyonel sent you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPiFF »</TD></TR><TR><TD CLASS="quote">
i'm assuming that your car is stored during the winter or used less. it would be nice to have abs during the winter, but if it's stored this would probably be a good step forward.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lyonel 13H4 »</TD></TR><TR><TD CLASS="quote">I would just go to http://www.evansautomotive.net and get in touch with Jeff Evans and tell him to pull the lines you need from a non ABS car and ship them to you. Evans Automotive is a Honda salvage yard and they have been very helpful to me. They have over 2000 salvage cars on their lot. Just tell them Lyonel sent you. </TD></TR></TABLE>
Email Sent
Email Sent
someone is LYING TO YOU!!!!! there is no way abs in total weighs 25 pounds!!! if that.....
and abs is a GOOD thing!!
and abs is a GOOD thing!!</TD></TR></TABLE>
Good ABS is a good thing (like the oem ITR abs). the GSR abs...errr...not so much IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
Good ABS is a good thing (like the oem ITR abs). the GSR abs...errr...not so much IMO. </TD></TR></TABLE>
All 98+ Integras have the good 4 channel inline ABS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and abs is a GOOD thing!!</TD></TR></TABLE>
I like it, but IT does not.
SCCA Club Racing - We fear technology and progress(tm)
You sure the later tegs had the same ABS the ITRs did? The ITR system was quite a bit better and lighter than the GSR system. Looks completely different too.
dustinbs144
Mar 6, 2011 06:08 PM
integrax97
May 3, 2007 12:15 PM
