obx cams are good
Old Dec 19, 2004 | 10:07 PM
BEEYOND's Avatar
Default obx cams are good
ok too many post saying obx lsd is good..
what about their cams???
exactly the same specs as sk2....
now what about them saying that they are hollowed for weight reduction???
hehe!!!
anyone try these hollow cams yet???
Old Dec 20, 2004 | 06:42 AM
egizzle8
Guest
Posts: n/a
Default Re: obx cams are good (lsvtecpower)
I was thinking about getting one on ebay since there pretty cheap. I believe there just skunk cams knockoffs. Exact same duration and lift numbers.
Old Dec 20, 2004 | 07:25 AM
BlackOnBlackTeggie's Avatar
Default Re: obx cams are good (egizzle6)
i think someone did a test , in a b18c , he had skunk2 stage 2 cams and bought a pair of the OBX cams stage 2, and he seeing if they do a rocker arm damage, cause some people said they are make of shity metal. i wanna find this guy cause i want to also buy a set
Old Dec 20, 2004 | 07:53 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: obx cams are good (BlackOnBlackTeg)
I would never rock the OBX.
Old Dec 20, 2004 | 08:09 AM
NathanMorris's Avatar
Default Re: obx cams are good (LSVTEC 91 Civic)
there was a thread where a guy dynoed them both - and they were exactly the same performance wise. The only question now is if the steel that they're made from (which is harder than the rocker arms) is going to trash the rocker arms - my bet is, over time....yep.
I'd grab some Crower cams, they're only like $385-400 *shrugs*.
- Nathan
Old Dec 20, 2004 | 11:46 AM
TypeR0207's Avatar
Default Re: obx cams are good (92Lx)
Check out Matix's thread responses on the obx cams that are in this forum (search obx cams in the "all motor" forum).
He has put over 2,500 miles on his in his H22, and just dynoed with them and made 209whp/159wtq. Stage 1's as well.
He's had absolutely no issues with them, or wear.
Old Jan 7, 2005 | 07:49 PM
Dai_Ca_Vietnam_H22a4's Avatar
I can test the metal in the lab. If someone is willing to scrap off a piece of metal a size of a grain of sand from each camshaft. The sample should not be contaminated. Send it to me, I will test the two metal in a laboratory setting. I will test for the hardness and the melting point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackOnBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">i think someone did a test , in a b18c , he had skunk2 stage 2 cams and bought a pair of the OBX cams stage 2, and he seeing if they do a rocker arm damage, cause some people said they are make of shity metal. i wanna find this guy cause i want to also buy a set</TD></TR></TABLE>
Old Mar 24, 2005 | 02:44 PM
Acura_I-RS's Avatar
Default Re: obx cams are good (Dai_Ca_Vietnam_H22a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dai_Ca_Vietnam_H22a4 &raquo;</TD></TR><TR><TD CLASS="quote">I can test the metal in the lab. If someone is willing to scrap off a piece of metal a size of a grain of sand from each camshaft. The sample should not be contaminated. Send it to me, I will test the two metal in a laboratory setting. I will test for the hardness and the melting point.
Now this would be very interesting!!! someone send this guy some shavings!!
BigDare23
Aug 1, 2009 02:28 PM
Ruben19
Jan 24, 2006 07:25 PM
1750cc
Dec 18, 2004 04:35 PM
B00ST2nR
Mar 1, 2003 01:59 PM
Isaac
Aug 20, 2002 05:52 PM
