2000 Accord side airbag light on???
Old Dec 19, 2004 | 09:41 PM
thejdmkid's Avatar
Default 2000 Accord side airbag light on???
I have a 2000 accord ex, and every once in awhile the side airbag light will come on. i notice it when i come to an abrupt stop sometimes and other times it will just come on for no provoking reason. does this happen to anyone else?? what could it be that is causing this, i'm thinking either the relay or is there a sensor in the seat itself that could be faulty???
Old Dec 20, 2004 | 01:38 AM
thejdmkid's Avatar
Default Re: 2000 Accord side airbag light on??? (thejdmkid)
Old Dec 22, 2004 | 11:46 PM
thejdmkid's Avatar
anyone?
Old Dec 23, 2004 | 01:09 AM
tsdenny's Avatar
when the side airbag light goes on, did you have a passenger? if your passenger leans a certain way, it sets off the light.
Old Dec 23, 2004 | 12:50 PM
Beach Accord's Avatar
read yer fackin manual....it explains it all!
Old Dec 23, 2004 | 01:15 PM
ForceXVII's Avatar
It could be the seatbelt buckle ish that needed to be replace. If SRS light shows then that could be z reason.
Old Dec 23, 2004 | 01:22 PM
he said side airbag....not SRS
two different lights
Old Dec 25, 2004 | 08:00 PM
thejdmkid's Avatar
Default Re: (Beach Accord)
read the manual, doesnt say much about faulty side airbag problems?
Old Dec 26, 2004 | 08:01 AM
Default Re: (thejdmkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thejdmkid &raquo;</TD></TR><TR><TD CLASS="quote">read the manual, doesnt say much about faulty side airbag problems? </TD></TR></TABLE>
there is no problem unless your SRS light comes on.
the side airbag light will come on from time to time...thats just the way it works.
and yes, the manual states that the light comes on for different reasons.
Old Dec 26, 2004 | 08:06 AM
iam7head's Avatar
they are pretty much act like that all the time.
it happens when you put something on the passenger side or during a turn
Old Dec 26, 2004 | 08:25 AM
ll kaidoy ll's Avatar
it's nothing to worry about. it does that time to time. like stated above, it mostly turns on when you have a passenger in the front passenger seat and they lean too far over to one side.
Old Jan 6, 2005 | 02:02 PM
SRS's Avatar
SRS
It could be the faulty seat belt latch problem.
My 2000 Accord SE SRS light was on for last couple of month. It was fixed for free under the seat belt (lifetime) warranty.
Old Jan 6, 2005 | 02:33 PM
philadd's Avatar
Default Re: (SRS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRS &raquo;</TD></TR><TR><TD CLASS="quote">It could be the faulty seat belt latch problem.
SRS and Side SRS are two different things, with two different warning lights. In your case it was the SRS. In thejdmkid's case, it's the side SRS, which isn't connected to the seat belt latches in any way.
Old Jan 6, 2005 | 03:33 PM
Caveman74's Avatar
Default Re: (philadd)
Mine does it. if you lean or pull on the seat it will come on. It just has really sensitive sensors.
Old Jan 6, 2005 | 06:37 PM
PrettyLude's Avatar
that is normal, if you put ur arm on the door panel it will trigger the light, or you lean a certain way it will trigger the light, that's normal
slixxracing
Nov 13, 2013 05:49 PM
evd
Nov 18, 2005 05:27 PM
joker8415
Jul 30, 2004 05:34 PM
