HELP...QUICK
Old Dec 19, 2004 | 07:33 PM
95greenlude's Avatar
Default oops....
....i bled my slave cylinder wrong...i opened the cylinder and just pumped the clutch, do i need a new slave cylinder??
Old Dec 19, 2004 | 08:48 PM
sleepin91teg's Avatar
Default Re: oops.... (95greenlude)
Um, WHAT? be more specific?
Old Dec 19, 2004 | 08:57 PM
PrettyLude's Avatar
two people would help when your bleeding the slave cylinder
Old Dec 20, 2004 | 08:41 AM
kickerx's Avatar
From what he said........ instead of have 2 people do it, he did it himself. and he just opened the slave bleeder and pumped away. you can tell he read the helms manual before doing this.
You'll have the put new fluid in the system, and will have the grab the clutch pedal and pull it up from the floor after every DOWN movement. There will be no fluid to push the pedal back up. After about a dozen times of bleeding the system CORRECTLY... it should slowly regain pedal pressure. Unless of course by moving the master cyclinder's piston out of the normally traveled wear path, you messed up the seals - in which case you just replace the master cylinder. You'll know if the pedal doesn't hold pressure.
Consult HELMS manual or honda-tech archives for proper bleeding procedure. Takes a whole 5-10 minutes.
alibat
Honda Civic (2001 - 2005)
Sep 4, 2018 07:51 AM
Born2Build
May 22, 2011 06:02 PM
Christopherian1982
May 25, 2009 08:10 PM
bruthaboost
Dec 10, 2001 05:33 PM
