what sensor is this?
i have a 95 gsr head and its next to the water temp sensor?? its black and has two pins in it , also there is a sensor on the thermo housing , is that the fan switch???
thanks honda-tech
thanks honda-tech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmGlenn »</TD></TR><TR><TD CLASS="quote">oh ok so the one on thermo is fan switch and the lil 2pin sensor by the oil pressure switch is the coolant temp for ecu not the cluster?</TD></TR></TABLE>
???? The obd0 motor had the thermo switch on the back of the motor and obd1+ has it on the thermostat housing.. Are you using a obd1 thermostat housing on an obd0 motor?
motegicivic
19
Oct 12, 2017 10:28 AM
