Vtec Solenoid help :(
Old Dec 19, 2004 | 01:00 PM
GDM Z28's Avatar
Default Vtec Solenoid help :(
i was putting on my vtec solenoid on my gsr and the bottom bolt broke. its flush with the head so i used a bolt extractor and then that pos broke so i used a dremel to level it again and tried another screw extractor but it wouldn't drill into the broken on. so i took the vtec solenoid and put hondabond over the gasket and put it on using the 2 screws left. it looks flush all around and isn't loose. do you think this will hold? has any one ever done this?
Old Dec 19, 2004 | 02:02 PM
GDM Z28's Avatar
Default Re: Vtec Solenoid help :( (civicflnum1)
someone please answer id like to know so i can sleep better at night
Old Dec 19, 2004 | 04:40 PM
HONDA_TYPE_R's Avatar
Lots of pressure runs through there...may be risky. I know I had a stripped bolt on my old solenoid, and the bitch dripped oil at idle...I can't imagine what it would have been like at VTEC. Try it if you dare, but beware.
Old Dec 19, 2004 | 10:24 PM
GDM Z28's Avatar
Default Re: Vtec Solenoid help :( (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">Lots of pressure runs through there...may be risky. I know I had a stripped bolt on my old solenoid, and the bitch dripped oil at idle...I can't imagine what it would have been like at VTEC. Try it if you dare, but beware.</TD></TR></TABLE>
well im hoping that the 2 bolts i have in there + the hondabond will hold it....i guess ill find out when i start it....if it leaks ill have to figure something out.
JDM787
Apr 16, 2016 04:54 PM
pmey
Feb 9, 2009 02:02 PM
92integraVTECgsr
Jan 22, 2007 12:26 PM
matthevelli
13
Jun 4, 2005 03:22 PM
