adjusting coilovers
Old Dec 19, 2004 | 11:59 AM
crazydyke's Avatar
Default adjusting coilovers
whats the best way to adjust coilovers and get all four sides evenly?
Old Dec 19, 2004 | 12:03 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: adjusting coilovers (crazydyke)
If you don't have corner weighting scales (and most don't) the next best thing to do is get the car on level ground, make sure the car isn't loaded down with junk in the trunk/hatch and start adjusting using a measuring tape against wheel gaps. Get everything relatively even and you should be set.
Old Dec 19, 2004 | 12:07 PM
Kyles ej1's Avatar
Default Re: adjusting coilovers (00Red_SiR)
i did mine by eye and when i measure it, it was almost perfect
Old Dec 19, 2004 | 12:08 PM
ek9800's Avatar
the thing that i do to make sure they're all even is count how many threads there is from the bottom to where the adjuster thing is.
Old Dec 19, 2004 | 08:12 PM
Yumm Tum Yummm's Avatar
eye that thing!
Old Dec 19, 2004 | 08:16 PM
Lil Corb's Avatar
Default Re: adjusting coilovers (ek9800)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 &raquo;</TD></TR><TR><TD CLASS="quote">the thing that i do to make sure they're all even is count how many threads there is from the bottom to where the adjuster thing is.</TD></TR></TABLE>
doesn't always work, my car is about even on all four sides and on one side it has so much more threads than the other.
Old Dec 19, 2004 | 08:17 PM
civictildeath's Avatar
Default Re: adjusting coilovers (EJ_FaNaTiK_22)
i put my front together and got them same height (according to coilovers) before i put them on and did the same with the rear but made the rear a little higher. they are within a mm of eachother.
Old Dec 19, 2004 | 08:28 PM
BauleyCivic's Avatar
Risky Business
Default Re: adjusting coilovers (civictildeath)
Use your fingers to measure the gap between the top of the tire and the fenderwell 1 finger gap ownz j00
Old Dec 19, 2004 | 08:32 PM
Default Re: adjusting coilovers (BauleyCivic)
i have 1 finger in the rear and none in the front
Old Dec 20, 2004 | 12:37 AM
xZeler8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Use your fingers to measure the gap between the top of the tire and the fenderwell 1 finger gap ownz j00</TD></TR></TABLE>
haha...that's how i did mine, still need to adjust a bit but the method is the same
Old Dec 20, 2004 | 05:15 AM
ErikV's Avatar
Measuring tape is your friend. Did my EG Civic Coupe with Tein SS in that way, it's perfect now
Old Dec 20, 2004 | 05:58 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (ErikV)
My **** is uneven and the allen key bolts on my Ground Controls are frozen so I cant adjust them. Im gonna get rid of them and buy some good springs and shocks. I never adjust the damn things anyway lol.
Old Dec 20, 2004 | 06:55 AM
ProJectCvic's Avatar
Default Re: adjusting coilovers (Lil Corb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb &raquo;</TD></TR><TR><TD CLASS="quote">
doesn't always work, my car is about even on all four sides and on one side it has so much more threads than the other.</TD></TR></TABLE>
What kind of coilovers do you have? This always works for me and my brother's cars. It must be shitty coilover i m thinking? They shouldn't sag that much from each other .
Old Dec 20, 2004 | 07:23 AM
Sour Diesel's Avatar
A measuring tape doesn't lie.
Old Dec 20, 2004 | 07:59 AM
HatchEh2's Avatar
Default Re: (B30M87A)
i count how many fingers from the bottom of the thread till the perch lock (fingers horizontal) then match it to the paralell side (rear right w/ rear left etc) make sure to keep in mind that when bringing the car back down, sometimes the spring will not go into the cuplet up top like it should. Then when ur driving and u hit a bump on that side or something the spring pops into place and suddenly that sides 3/4 in lower...
could just be my **** but, i dont doubt it happens with others
chisaiCheesam
Honda Civic (2006 - 2015)
Mar 1, 2008 11:41 AM
k_lude
Mar 8, 2007 11:52 PM
Mr. Eric
Suspension & Brakes
13
Mar 28, 2005 05:13 AM
Honissan
12
May 4, 2004 03:20 PM
pr0jektdc2
Feb 15, 2004 01:56 PM
