B16 + GT30R @ 10psi how much whp?
Hallo,
does anyone drives the combination mentioned in the topic? and how much power does this setup produce?
i know that there are a lot of parameters like cr, octane, tuning, intercooler, manifold etc.... but i want to get a feeling for this.
Thanks
Malte.
Thanks
Malte.
my numbers in my sig below are,B18C5, Gt30R @ 15psi, 11.1-11.4 a/f . 21.75 total timing, pump gas. maybe that will get you close to what your looking for or until someone else chimes in.
nice numbers.
but i have a question concerning your timing. where did you have 21,75° ?!? under full boost?
what cr?
for my oppinion thats damn advanced for 15psi how much octane are you running?
but great numbers, respect.
what cr?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DontBlink »</TD></TR><TR><TD CLASS="quote">my numbers in my sig below are,B18C5, Gt30R @ 15psi, 11.1-11.4 a/f . 21.75 total timing, pump gas. maybe that will get you close to what your looking for or until someone else chimes in.</TD></TR></TABLE>
Never mind... nice setup :-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx »</TD></TR><TR><TD CLASS="quote">Hallo,
Thanks
Malte.</TD></TR></TABLE>
Based upon my calculation with a few variances, you're looking at about 268whp w/ 1.68 pressure ratio, 89.2% Volumetric Efficiency, and about 34.9lbs/min exhaust flow from 1595cc of displacement.
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Based upon my calculation with a few variances, you're looking at about 268whp w/ 1.68 pressure ratio, 89.2% Volumetric Efficiency, and about 34.9lbs/min exhaust flow from 1595cc of displacement.</TD></TR></TABLE>
can you tell me more details about your calculations? (only interested)
Thanks
Malte.
Thanks
Malte.
Thanks
I can really say as complicated as it may seem, I used your exact cc displacement, including bore,stroke, utilized 89.3% Volumetric efficiency of the b-16 motor, and was able to take into account 4 RPM points in which I look at stabilized consistancy in the powerband. I did NOT use turbo-calculator.com for any information. I do this for a living.
Thanks
GreeceS13
Engine Management and Tuning
Jun 4, 2016 12:17 PM
marsvolta
15
Mar 12, 2005 09:51 AM
