GT SERIES water cooled turbo lines?Pics???Advice????
Old Dec 19, 2004 | 01:43 AM
darkdayz's Avatar
Default GT SERIES water cooled turbo lines?Pics???Advice????
I've read mixed views aboout where to tee off lines for the coolant lines on a water cooled turbo.....near throttle body and heater core lines. Does one have an advantage over the other and Anyone have pics of their setup
Old Dec 19, 2004 | 05:09 AM
SiRkid's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (darkdayz)
tb
Old Dec 19, 2004 | 07:18 PM
darkdayz's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (SiRkid)
thanks
Old Dec 19, 2004 | 07:26 PM
CivicEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">tb</TD></TR></TABLE>
that's where I got my coolant to flow into my turbo.
Old Dec 19, 2004 | 07:32 PM
darkdayz's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (CivicEJ1)
and everything works well with it off the tb?
Old Dec 19, 2004 | 09:13 PM
darkdayz's Avatar
bump for more info and possibly pics
Old Dec 19, 2004 | 10:08 PM
darkdayz's Avatar
late late bump
Old Dec 19, 2004 | 10:18 PM
IntegracinGSR's Avatar
I'd like to know too..
Old Dec 19, 2004 | 11:06 PM
pornstarSR's Avatar
Default Re: (IntegracinGSR)
tappin in near the TB is good because the line is either right off the rear water pipe which is a good feed off the waterpump.
Old Dec 19, 2004 | 11:23 PM
darkdayz's Avatar
Default Re: (pornstarSR)
thanks for the advice
Old Dec 19, 2004 | 11:24 PM
SOHC_MShue's Avatar
anyone got decent pics of how they ran theirs?
Old Dec 20, 2004 | 01:48 PM
darkdayz's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (SOHC_MShue)
bump
Old Dec 20, 2004 | 02:35 PM
11psiTurboSI's Avatar
Do you have to run the coolant lines for the GT turbos?
Old Dec 20, 2004 | 02:56 PM
Marauder's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to run the coolant lines for the GT turbos?</TD></TR></TABLE>
No.
On my D series, there is a small water hose that runs from the intake manifold to the throttle body. You throw that hose away and run a water line from the manifold to the turbo, then the other turbo line to the throttle body. Piece of cake.
Old Dec 21, 2004 | 02:07 AM
darkdayz's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (Marauder)
sounds good,thanks
Old Dec 26, 2004 | 03:32 PM
kevino002's Avatar
bump
Old Dec 28, 2004 | 01:42 PM
kevino002's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (kevino002)
anyone have pics of the water lines ran for the Gt2871r?
Old Dec 28, 2004 | 07:10 PM
O3DigitalBath's Avatar
bump
Old Dec 29, 2004 | 05:30 PM
kevino002's Avatar
Default Re: (O3DigitalBath)
_____________________________$$$____$$____________ _____$$$__________ _$$$$$$$$$$$$$___$$__________$$$__$$$$____________ ___$$$$$$$$_______ $$$$$$$$$$$$$$$_$$$$________$$$$__$$$$___________$ $$_$$$$$$$$$$_____ $$_$$$____$$$$$_$$$$________$$$$__$$$$__________$$ $$__$$$$$$$$$$____ __$$$$_____$$$$_$$$$_______$$$$___$$$$_________$$$ $$__$$$$_$$$$$$___ _$$$$$___$$$$$__$$$$_______$$$$___$$$$$______$$$$$ $$__$$$$___$$$$$__ _$$$$__$$$$$____$$$$_______$$$$__$$$$$$_____$$$$$$ $___$$$$____$$$$__ _$$$$$$$$$______$$$$______$$$$___$$$$$$$__$$$$$$$$ $___$$$_____$$$$__ $$$$$$$_________$$$$______$$$$___$$$$$$$$$$$$__$$$ ___$$$$_____$$$$__ $$$$$$$_________$$$$_____$$$$____$$$_$$$$$$$___$$$ ___$$$$____$$$$___ $$$$$$$$$$$_____$$$$_____$$$$____$$$___$$$____$$$$ ___$$$___$$$$$$___ _$$$_$$$$$$$$___$$$$____$$$$$____$$$__________$$$_ ___$$$$$$$$$$_____ _$$$_____$$$$$___$$$$__$$$$$$____$$$__________$$$_ __$$$$$$$_________ _$$$____$$$$$$___$$$$$$$$$$$____$$$$__________$$$_ _$$$$_____________ _$$$$$$$$$$$$$____$$$$$$_$$$$___$$$__________$$$__ __$$$_____________ $$$$$$$$$$$________$$$___$$$$___$$$__________$$___ __$$$$____________ $$$$$$$___________________________________________ __$$$$____________ _$$_______________________________________________ __$$$_____________
For Pics
Old Dec 29, 2004 | 09:05 PM
Aquafina's Avatar
For those of you that are water cooled, how much are your coolant temps affected? I'm doing some research into a setup for HPDE's but am afraid 30 minutes of lapping on a water cooled turbo could get way to hot to be able to handle it.
Old Jan 5, 2005 | 08:12 AM
kevino002's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (Aquafina)
need more info and pics
Old Jan 5, 2005 | 08:42 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
No.
On my D series, there is a small water hose that runs from the intake manifold to the throttle body. You throw that hose away and run a water line from the manifold to the turbo, then the other turbo line to the throttle body. Piece of cake.</TD></TR></TABLE>
You don't HAVE to, but for longevity of that bearing system, for what you've paid for, you'd better...
Old Jan 5, 2005 | 09:13 AM
kevino002's Avatar
Default Re: GT SERIES water cooled turbo lines?Pics???Advice???? (TheShodan)
I hear that my gt2871r was not cheap. I hurd that tuner toys has a water cooler kit but they are all out of them. does anyone know of anywhere else that you can get one.
Old Jan 5, 2005 | 09:33 AM
ohboy95c's Avatar
I don't have any experience with the gt's but i'm imagining with a little amount of fab any small cooler should work. ie one from a bike or even on made for like psor oil. Do you have a bigger radiator and fan though. Because tons of more heat is created by exaust gasses throughout the system than cooling lines on a turbo. If your concerned I'd look at my radiator and fan .
Old Jan 5, 2005 | 09:54 AM
TeStUdO's Avatar
I would like to see pics of this as well. On a DSM it is much easier considering they are factory turboed and come water cooled. Bump for a pic.
