sleeving AFTER pistons??
Old Dec 18, 2004 | 08:06 PM
bjfisher's Avatar
Default sleeving AFTER pistons??
ok heres the deal, i will be sleeving my h23 block for turbo, however right now i need to get it running asap, so is it alright to go ahead and get my pistons and rods and install them, then later on once i have the motor running i can sleeve it?i just wanna make sure that nothing will need to be altered or that i wont have an problems, because i dont have the money right now to do it all at once unfortunatly and i'm in a hurry to have a running car...
Old Dec 19, 2004 | 03:43 PM
NJIN BUILDR's Avatar
Default Re: sleeving AFTER pistons?? (bjfisher)
You can't run a forged piston against the stock cylinder walls.You could run stock pistons only without sleeving!
Glenn
Old Dec 19, 2004 | 04:10 PM
DavidT or VajT's Avatar
Default Re: sleeving AFTER pistons?? (NJIN BUILDR)
Pistons have a tendency to break after being pushed out of the block. Just wait till you have money to do the whole shabang
Old Dec 19, 2004 | 04:13 PM
jlacoy82's Avatar
71.192.16.183
Why cant you run forged pistons in stock cylinder walls? What if they are the same bore? :\
Old Dec 19, 2004 | 04:27 PM
v4lu3s's Avatar
RTFM
because you will tear the hell out of the cylinder walls and most likely seize your engine. the cylinder walls are made of FRM which is aluminum rather than iron.
Old Dec 19, 2004 | 04:29 PM
Default Re: sleeving AFTER pistons?? (jlacoy82)
H22 & H23 use special material in the stock cylinder wall that only work with stock cast pistons.You must sleeve the block to use aftermarket pistons.
Glenn
Old Dec 19, 2004 | 04:36 PM
bjfisher's Avatar
ok thanks guys, thats what i thought but was hoping i was wrong lol.....i'll just wait and do sleeves/pistons/rods all at once then my bottom end should be set right?
Old Dec 19, 2004 | 04:44 PM
Default Re: (bjfisher)
How much are you expecting to boost and what compression are you going to run? Take this info:
Compression <Boost
10.5:1 <8psi
10:1 <10psi
9.5:1 <12psi
9:1 <14psi or more
Good luck with everything...
Old Dec 19, 2004 | 04:57 PM
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">H22 & H23 use special material in the stock cylinder wall that only work with stock cast pistons.You must sleeve the block to use aftermarket pistons.
Glenn</TD></TR></TABLE>
Not to hijack, but what about d-series engines? I've just never heard of this. I knew about sleeving and honing, but never knew it was for this specific reason.
Old Dec 19, 2004 | 05:24 PM
PrettyLude's Avatar
d series don't have the frm on the liners
Old Dec 19, 2004 | 05:28 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (PrettyLude)
Neat, so I can hone and go! Thanks! /return to original topic
Old Dec 19, 2004 | 06:58 PM
bjfisher's Avatar
Default Re: (DavidT)
i'm getting 9:1 pistons,je or cp
i want to run atleast 15 +
Modified by bjfisher at 8:20 PM 12/19/2004
turboman2.2
Feb 12, 2010 12:43 PM
JDMotive
May 28, 2004 02:26 PM
crxrich_kid
Feb 21, 2004 01:25 PM
Ri5e
Apr 3, 2003 08:52 PM
p10hlm
Jan 7, 2003 11:25 PM
